Demon4x4.com • View topic - Project Flat Panel Samsung LCD install
Postby Kris Guilbeaux » Fri Sep 21, 2007 5:45 pm
This Thread is to show the install of my New 23" Samsung Flat panel install.
Thread will include pictures so stay Tuned.
Install will be Mounting the TV to the Wall, running the Electrical and setting up surge protection built in to the Wall for clean installation.
This is a No Wires hanging install. the Way it was meant to look...
Stay tuned
Postby Kris Guilbeaux » Mon Sep 24, 2007 5:42 pm
So hunting all the parts to do a clean install with no cords Showing turned out to be a quite a chore.. So needless to say I made some pieces to do this.
First order was to Run a in wall RCA line with along with Cable TV wire.
I found this Product at Radio Shack which would work perfect behind the dresser but lacked TV cable. I bought two one to use as is and one to use for parts.
I purchase the The next parts at Lowes to make my own plate to make use off the RCAs and Cable TV.
I drill holes in the blank plates, attach the RCAs and Cable to the blank.
Walla!!!
Next To cut the proper holes in the Sheet rock.
I tied My Elec into the plug exactly below where the New Tv would go. I turn off the breaker to the room and remove all the Existing Metal box for the plug. and install New Deep Remodel Boxes and Low Voltage boxes for the RCAs and Cable.
I purchase a outlet Surge protector for the TV this was purchased at an Electrical store in Victoria. Cable was ran in the Attic and Drilled a Hole threw the Header to run the cable in the wall. I lost a Few pounds in the Attic this Morning. LOL
At that point I secured the Wall mount for the TV to the Stud in the Wall and hooked Every thing up..
Postby FROADER » Mon Sep 24, 2007 6:01 pm
Nice clean install Kris. :8)
Colin
:froader
FROADER
Postby wilander » Mon Sep 24, 2007 6:14 pm
That is a wonderful install. What type of Surge protector did you use and where did you mount it?
Bart/Lisa - "Grandpa, didn't you wonder why you were getting checks for doing absolutely nothing?"
Grandpa - "I just figured the democrats were in power again."
wilander
Denim Dandy
Postby Kris Guilbeaux » Mon Sep 24, 2007 7:21 pm
Postby Justin Klare » Mon Sep 24, 2007 9:46 pm
Postby SVO » Tue Sep 25, 2007 6:54 am
Postby Tripany » Tue Sep 25, 2007 8:18 am
Tiffany
1994 Lincoln Mark VIII
"The Dark Mark"
"You can always trust the information given to you by people who are crazy...
they have an access to truth not available through regular channels" -Sheila Ballantyne
Tripany
Postby XanaDorn » Tue Sep 25, 2007 11:03 pm
XanaDorn
Users browsing this forum: No registered users and 20 guests
