Demon4x4.com • View topic - EEE's 1993 Ford Explorer
Re: EEE's 1993 Ford Explorer
Postby Kris Guilbeaux » Fri Jan 31, 2014 12:33 pm
The two vehicles will be moved this weekend to the drive way in prep of the swap . The new stands arrive feb 5th and I will have the 93 prepped before that
Postby KF5ZXT » Fri Jan 31, 2014 12:40 pm
Do you happen to know the size/thread pitch/etc. of the body mount bolts? I could acquire some Grade 8 or 9 versions to stick in while we're in there.
Found this for a second gen, not sure if same.
Postby TxPlates » Fri Jan 31, 2014 2:09 pm
So is the swap still planned for the 18th?
Postby Kris Guilbeaux » Fri Jan 31, 2014 11:26 pm
The factory bolts are already a grade 9 from the factory just an FYI
Postby Kris Guilbeaux » Fri Jan 31, 2014 11:27 pm
And the swap is planned for feb 22-23rd
Postby KF5ZXT » Mon Feb 03, 2014 10:08 am
So, are you thinking of straddling two pipes/beams/supports/whatever across the 4 pipe stands, to a width wide enough to accommodate both bodies? Or are you thinking of just cutting up the black one on the frame it currently sits, and have only the white body up on the stands, and just move the drivetrain out from under it?
Also, I just remembered that the door speakers in the black body are pretty decent: Clarion Pro Audio 5x7 plate/components. I'll have to transfer those over.
Postby Kris Guilbeaux » Mon Feb 03, 2014 11:06 am
The white body will go on the stands and we will cut up the black trucks body once the frame is out from the white one
Postby Kris Guilbeaux » Mon Feb 03, 2014 11:17 am
I also moved the donor and your truck out of the back yard last night. I have to get the Buick out of the garage and will start final prep work on the 93 donor.
Postby KF5ZXT » Sat Feb 08, 2014 11:05 am
Any more details for what we are planning to get accomplished the weekend of the 22-23? Anything else need to be brought? I'm guessing the trailer is no longer needed.
Postby Kris Guilbeaux » Sun Feb 09, 2014 9:23 am
The plan that day is to get the body on the frame of the 91 and swap over the wiring harnesses I am going to work on the 93 body the weekend of the 15-16th and get it prepped to be lifted off the frame in my driveway
Postby KF5ZXT » Mon Feb 10, 2014 4:01 pm
Postby TxPlates » Tue Feb 11, 2014 9:05 am
All done I see.
Postby Kris Guilbeaux » Tue Feb 11, 2014 11:22 am
I been working on getting the truck ready the
Postby Kris Guilbeaux » Tue Feb 11, 2014 11:24 am
I'm glad you notice that I at least give a time frame and deliver on my promised times
Postby TxPlates » Mon Feb 17, 2014 5:19 pm
Can we set up the camera that Russell bought to record the swap and burn it on a DVD?
Postby Kris Guilbeaux » Tue Feb 18, 2014 11:01 am
Yes we can we planed on filming
Postby KF5ZXT » Tue Feb 18, 2014 11:10 am
Reminder to self: I still need one passenger side fender, a header panel, headlight assemblies. Anything else?
Postby TxPlates » Wed Feb 19, 2014 9:37 pm
Shouldn't the header panel from the donor vehicle be avail? As far as lights you should still do the 95 conversion to throw another different look in the mix for the new set up.
Postby KF5ZXT » Wed Feb 19, 2014 10:46 pm
Needs a second gen header panel... in order to do the 95 lights.
Postby TxPlates » Thu Feb 20, 2014 8:35 am
Maybe kris has one laying around?
Postby KF5ZXT » Thu Feb 20, 2014 9:11 am
Nope, he's the one who relayed to me the need for it.
Postby Kris Guilbeaux » Thu Feb 20, 2014 1:01 pm
Parker the donor vehicle is a 93 so a 93 won't have a 95 header panel. I already figured up the stuff that was needed to complete. I took all the laying around parts I have.
Postby KF5ZXT » Thu Feb 20, 2014 1:16 pm
I was looking on Rock Auto for the header panel (FO1220202/F5TZ8190A). They have an 'Economy Line' for $30.79, a 'Regular Inventory' for $38.99, and a 'CAPA Certified' for $117.79. Any idea what the differences would be? I also noticed that the 1997-2001 has different part numbers (FO1220217/F87Z8190CA). What would be the difference between the 95-96 vs. 97-2001?
Postby TxPlates » Thu Feb 20, 2014 4:07 pm
Capa is a certified part insurance companies use. In my opinion they're all the same is go with the cheaper part. They're all coming off the same mold, Capa goes through additional certification steps.
Postby KF5ZXT » Fri Feb 21, 2014 10:29 am
I'm told the difference in the header panels is the hump for the hood latch. I'm in need of a 97-01.
