Demon4x4.com • View topic - EEE's 1993 Ford Explorer
Re: EEE's 1993 Ford Explorer
Postby KF5ZXT » Wed Feb 26, 2014 9:19 am
Ok, so far I need:
Radiator :check
E-brake pads
handle :check
Reverse light switch :check
Amplifier
Headlights
Rear winch wire :check?
CB antenna and NMO mount
Winch switches
Anything else?
Postby nice59fordf100 » Wed Feb 26, 2014 10:02 am
Ill let kris chime in on the body stuff, but i think we have all that. we also have an idea on how to modify the drill to surround the winch a bit better. do you want chome explorer grille, black explorer grill, painted normal explorer grille, or limited grille?
also need wiring for rear winch. ill need to see the sub enclosure you want to run so i know which amp will fit inside there
Postby Kris Guilbeaux » Wed Feb 26, 2014 10:20 am
I'd say get some new headlights I have stock markers and turns. I think I have at least one good headlight door but those are cheap.
Postby KF5ZXT » Wed Feb 26, 2014 11:22 am
Yeah, I've actually got a black one lying around as well. Can't remember which side though. The whole middle section of the limited grill would end up getting cut out, so I'm thinking black Explorer grill. What do you mean about 'an idea on how to modify the grill to surround the winch a bit better'?
Postby KF5ZXT » Wed Feb 26, 2014 12:15 pm
How many feet of cable do you think I need for the winch?
Postby nice59fordf100 » Wed Feb 26, 2014 4:06 pm
Postby KF5ZXT » Wed Feb 26, 2014 4:10 pm
Current Draw (No Load) 56 amps
Current Draw (Max Load) 478 amps
Postby nice59fordf100 » Wed Feb 26, 2014 7:42 pm
478 AMPS?? Jesus thats a lot, even for a winch under max load....i would almost recommend running a dual battery setup with an isolator. run a second battery to the rear, then run your cable to the rear battery to the rear winch. isolator between the two batteries and presto - suffiecent amp draw and the ability to 'jump' your starter battery should it ever go dead. just an idea. if not, your looking around 2/0 wiring
Postby KF5ZXT » Wed Feb 26, 2014 8:02 pm
2/0 is what I had figured on, as well. I've heard differing opinions on the dual battery setup. Wouldn't having the second battery in the rear still have to run a similar set of wires to the primary?
Postby zavaral » Wed Feb 26, 2014 8:48 pm
Since Yall are talking about lights and i need to lose some light. I have a set of those "hard to find" completely clear tail lights if your interested. My dad has them stashed somewhere so let me know if you want em or they can stay in where ever they are...
Sent from my SGH-M919 using Tapatalk
Postby KF5ZXT » Wed Feb 26, 2014 9:10 pm
I'm one of those weirdos that actually likes red brake lights. Thanks though. Perhaps someone else would like them?
Postby zavaral » Wed Feb 26, 2014 9:59 pm
Just figured with everything new. I like the Reds too. It was just a stage.
Postby KF5ZXT » Wed Feb 26, 2014 10:00 pm
Yeah, I hear you. I did the clear corners in the front for a while, before I got old. lol
Postby zavaral » Wed Feb 26, 2014 10:52 pm
Now I don't mind the clear corners.... I don't particularly like orange plastic. Clear with the orange reflector don't bother me. I don't like the crystal clear, or euro style. But the clear corners on white look good
Postby nice59fordf100 » Thu Feb 27, 2014 9:36 am
Postby KF5ZXT » Thu Feb 27, 2014 9:58 am
I am aware of ohm's law, but the same principal would still apply to the wire from the alternator. What gauge wire would I need, then? Also, where would the battery be mounted?
Postby nice59fordf100 » Thu Feb 27, 2014 10:37 am
Postby KF5ZXT » Thu Feb 27, 2014 11:21 am
At any rate, the options are really:
1) 14 feet of 2/0 AWG wire handling 400+ amps
2) 14 feet of 4 AWG wire handling 90+ amps, plus an isolator, plus an additional deep cycle battery.
So if it's just a cost issue - seems like a wash.
Oh well - I just hopped on Amazon and jumped on this, everyone else should probably go ahead and do the same, never know when you might need some...
:shock
Postby nice59fordf100 » Thu Feb 27, 2014 11:50 am
we can give it a go and try!
Postby nice59fordf100 » Thu Feb 27, 2014 12:25 pm
im still trying to find a link for 1/2" wire loom...you will need red and black colored
Postby Kris Guilbeaux » Thu Feb 27, 2014 7:12 pm
I did make three trips to the recycling center today and repaired the door panel.
Postby KF5ZXT » Thu Feb 27, 2014 7:14 pm
Bye bye black truck. :'(
Postby zavaral » Thu Feb 27, 2014 10:52 pm
It's a sad sad day
Postby KF5ZXT » Fri Feb 28, 2014 10:50 am
Radiator and 25' of 4 gauge welding wire purchased and shipped to BC address.
This is the that I was looking at. I was thinking of sticking it where the stock 4x4 switches would be, if this truck were a 4x4. :lol
Postby nice59fordf100 » Fri Feb 28, 2014 12:16 pm
