by Kris Guilbeaux » Thu Nov 07, 2013 10:55 am
Actually yes Randall on both accounts. But most first gens are wired for both auto and manual you would just change the harness for the transmission and you are golden. But sadly this is a limited and ford didn't pre wire first gen limiteds for manual trans. So to keep the PCM from freaking out and make it work like a stock explorer with manual trans we needed to add a few circuits that the limited was missing and delete a few and add a couple 20 ohm resistors. To trick the PCM to think it still has the auto trans in place.
Randall's truck spends more time in the Garage than the Trails...
