Demon4x4.com • View topic - 2006 Nissan Xterra Zombie Response Vehicle
Re: 2006 Nissan Xterra Zombie Response Vehicle
Postby BigTim55 » Thu Aug 30, 2012 8:07 pm
Postby BigTim55 » Thu Aug 30, 2012 8:29 pm
So after this incident I think I will be set back on the mods for a little bit. But a list of things I wanna try and at least buy before the end of the year: opinions and advice wanted/encouraged B-)
Tires: 35s of course lol, I think I wanna stick with an all terrain since it is my DD.
Alcans: these are needed so my truck doesn't look like I'm hauling a bunch of fatties around lol. Thinking either 2 or 3 inch lift setting.
Rear locker: I really don't know much about this so tell me what I need to know. Lol
Maybe:
Gears: people on thenewx say that changing your ratio will help with bigger tires and all that jazz. Again something I really know nothing about lol.
And if you're still reading after this paper I just wrote...
IT STARTED WITH A WHISPER!!!!!!!
Postby KF5ZXT » Thu Aug 30, 2012 8:41 pm
I was all set to help you out til I got to the end!
Postby BigTim55 » Thu Aug 30, 2012 8:44 pm
Postby Justin Klare » Thu Aug 30, 2012 8:53 pm
Tim try to find out what gear ratio you have and we can help you select your new ratio for your 35's. You can have the locker put in at the same time you change the gears out.
Postby KF5ZXT » Thu Aug 30, 2012 9:03 pm
There will either be an identification plate on the rear axle itself, or you can use the vim number to find out.
Postby BigTim55 » Thu Aug 30, 2012 9:45 pm
Postby KF5ZXT » Thu Aug 30, 2012 9:48 pm
Postby BigTim55 » Thu Aug 30, 2012 9:55 pm
Postby BigTim55 » Fri Aug 31, 2012 9:47 pm
Diff:c200k ratio 3.13
Postby MrQ » Fri Aug 31, 2012 11:12 pm
3.13's? :o Yuck! I'm surprised you are getting any power at all with 35's or anything else for that matter. Once you push the gearing up to or around 4.56, you'll see your engine get its cahone's back...providing of course that it had any to start with. :finger :D
Edit: Ahh, I see you are not running 35's yet...bad juju if you don't regear first. It won't only be your engine that hates you, but also your transmission.
I have 3.73's with 33's and I'm not making any records in the quarter mile, not that I haven't tried :wink . Fortunately its not so bad when you are up to speed, its just getting there that takes time. Did have Red up to 95 for a while with no problems, but it took about 30 seconds to get there from 70.
Postby KF5ZXT » Fri Aug 31, 2012 11:38 pm
You need to keep in mind that he does not drive an explorer.
Postby TexasArmadillo » Fri Aug 31, 2012 11:44 pm
I feel cultured. I drove a Chevy today.
Postby MrQ » Fri Aug 31, 2012 11:51 pm
Ehh, true. I guess I'm ingrained with Ford. Still the application of gear ratios vs. tire size and the impact on the rest of the drivetrain isn't that different. Unless Nissan has come out with a way to ignore physics.
Postby Justin Klare » Sat Sep 01, 2012 12:34 am
I think around a 3.73 would be good for your Tim.
Postby KF5ZXT » Sat Sep 01, 2012 7:56 am
3.73 isn't available for his axle. (nearest match would be 3.69). You guys shouldn't just guess when making recommendations for other people. Do some research. Nissan engines operate in a different RPM range than explorers.
What was the stock tire size?
This is the formula you'll want to use:
New tire diameter x original ratio / Old tire diameter
Postby TxPlates » Sat Sep 01, 2012 10:10 am
And always, and I mean this. Make sure your lug nuts are tight.
Postby BigTim55 » Sat Sep 01, 2012 10:24 am
You tell 'em Randall put Klare in check! Lol make him say uncle again!
Parker: I check them before I drive now, I'm super fuckin paranoid now
Postby Justin Klare » Sat Sep 01, 2012 1:52 pm
Tim you bitch, he never made me say uncle lol
Postby TxPlates » Sun Sep 02, 2012 9:12 am
No way to live your life Timmy.
Postby BigTim55 » Tue Sep 04, 2012 3:06 pm
http://www.creativeminorityreport.com/2 ... t.html?m=1
Postby KF5ZXT » Tue Sep 04, 2012 3:13 pm
LMAO. "That's a clown question, bro." - Bryce Harper.
Postby TxPlates » Wed Sep 05, 2012 6:37 pm
Another thread gone off track... at least it was funny.
Postby TexasArmadillo » Thu Sep 06, 2012 7:16 am
Wait, we should stay on topic in threads?
Postby TxPlates » Thu Sep 06, 2012 7:46 am
Guess not.
Users browsing this forum: No registered users and 4 guests
