Demon4x4.com • View topic - Rock Trac - 2001 Ford Explorer Sport Trac 4x4
Re: Rock Trac - 2001 Ford Explorer Sport Trac 4x4
Postby TxPlates » Tue Mar 20, 2012 8:36 pm
I will say yes, without knowing.
Postby KF5ZXT » Tue Mar 20, 2012 9:21 pm
Hahaha. Thanks Parker, you're the best.
Postby TxPlates » Tue Mar 20, 2012 10:47 pm
:P
Postby TxPlates » Thu Apr 12, 2012 8:52 pm
Well got the tranny leak fixed. Figured out too now that OD doesn't work????
Postby Justin Klare » Thu Apr 12, 2012 11:10 pm
Be glad if you have to pull the tranny your's will come out, unlike mine that stayed in the truck.
Postby nice59fordf100 » Fri Apr 13, 2012 7:56 am
Is the tranny fluid topped off? If its low, the tc wont lock up. Are you sure its od Thats gone and not tc lockup
Postby KF5ZXT » Fri Apr 13, 2012 9:41 am
He says that the button isn't doing anything - and no dash light indication. Perhaps electrical?
Postby Kris Guilbeaux » Fri Apr 13, 2012 11:21 am
Looks like that will be one of the first fixes when Russell moves down. I very seriously doubt its an issue with the trans thou. Most likely wiring or something is unplugged.
Postby TxPlates » Fri Apr 13, 2012 1:49 pm
Yea I lack original thought it's running fine, don't think it's thR tranny at all.
Postby nice59fordf100 » Fri Apr 13, 2012 2:59 pm
Just off the top of my head. Check for a small two pin connector under the dash to the right of the steering column...Thats where the overdrive cancel switch connects to dash harness. Ill double check when I get home for yea
Postby TxPlates » Fri Apr 13, 2012 6:28 pm
Do I have to take off the cluster to check this ?
Postby nice59fordf100 » Fri Apr 13, 2012 7:41 pm
Nope, you should be able to locate it without removing anything
Postby TxPlates » Fri Apr 13, 2012 7:47 pm
Alrighty I'll give it a try tomorrow.
Postby nice59fordf100 » Fri Apr 13, 2012 8:25 pm
also, check fuses f2.11 (7.5A) and f2.27 (15A) under the hood
Postby TxPlates » Tue Apr 17, 2012 8:03 pm
Postby KF5ZXT » Tue Apr 17, 2012 8:07 pm
:lol
Postby TxPlates » Tue Apr 17, 2012 8:08 pm
Fuse?
Postby TxPlates » Sat May 05, 2012 10:51 am
Well still no OD.
Good news is I located the issue with the drain on the battery. Turns out, there are midgets living inside the Trac using the radio while I'm not looking.
Ok, actually apparently the kids had kicked the on switch to the power inverter that's hard wired in, oops. I took the battery up to Autozone where I bought it back in September, and the dude was having a bad day and didn't even bother to test the battery and just swapped it out. Win win for me haha.
Postby nice59fordf100 » Sat May 05, 2012 9:37 pm
Thats good you found the power drain. Still strange about the od not working. Im wondering is the switch is bad. Ngs can tell for sure. When would you want me to cone out? (i can say that now! Lol, Im a Texan)
Postby TxPlates » Sat May 05, 2012 10:21 pm
Anytime you want :) The lights in the gauges worked for 5 mins tonight then went back off again. Odd.
Postby nice59fordf100 » Sun May 06, 2012 9:54 am
ok, depending on what kris has planned, i might be able to make it over this next weekend, just depending. if not, then the next (of course this depends on my job situation) Also, when are we swapping out the core support and inner fender supports?
Postby KF5ZXT » Sun May 06, 2012 9:55 am
Why are we doing that?
Postby TxPlates » Sun May 06, 2012 10:02 am
Cause the ones on the trac are heavily rusted.
Postby TxPlates » Fri May 11, 2012 2:25 pm
Well I'm probably heading up to Austin to purchase this bad boy tomorrow...
http://www.harborfreight.com/9000-lb-of ... keycode%5D
Postby KF5ZXT » Fri May 11, 2012 2:27 pm
I approve. :thumbup
