Demon4x4.com • View topic - Dan's Red Flyer II
Dan's Red Flyer II
Re: Dan's Red Flyer II
Postby KF5ZXT » Fri Oct 19, 2012 10:35 am
That is something that has yet to be determined, but will be discussed prior to us making a run. That EF list is probably a good place to start.
Postby MrQ » Fri Feb 15, 2013 6:27 pm
Tax return is on its way and I have some goodies in mind for Red. Moab, here I come!
Dan's Red Flyer II
Postby KF5ZXT » Fri Feb 15, 2013 7:07 pm
Why so vague? :shrug
Postby BigTim55 » Fri Feb 15, 2013 8:37 pm
Maybe he doesn't want you to steal his ideas
Sent from Xavier's School for Gifted Youngsters
Postby KF5ZXT » Fri Feb 15, 2013 9:51 pm
Well played Tim, well played.
Postby TxPlates » Fri Feb 15, 2013 10:01 pm
Well Tim is right, there seems to be a rash if thefts around here, I can't blame Dan for keeping said upgrades a secret for fear of theft.
Postby BigTim55 » Fri Feb 15, 2013 11:13 pm
Off with their hands!!!!!!
Postby TxPlates » Fri Feb 15, 2013 11:39 pm
If that's what it's takes.
Postby MrQ » Sat Feb 16, 2013 11:59 pm
Well my tax return should cover all my upgrades with some left over, including new shocks, the locker, and a full size spare tire. Either that or pick up a heavy duty dodge pick-up I have my eye on. :D
Postby MrQ » Thu Dec 12, 2013 6:08 pm
Ok, Red is going up to Austin this weekend for maintenance and repair from the people who built it. Seems fitting. I'll have to be towing it as apparently my key transponder got erased while trying to start the thing. :confused In any case Russell is going to give it a good going over and give me an idea of what the damage is.
If it is another fuel pump, or tank or filter or ANYTHING fuel related, I have matches and I know right where to strike 'em. :x
Postby TxPlates » Thu Dec 12, 2013 7:20 pm
Good luck sir.
Postby nice59fordf100 » Mon Dec 16, 2013 8:37 am
Red bull is at the shop. Installed new pcm, programmed keys, drove truck off trailer. Has a fuel leak down issue, had an egr fault (which by the way, got the new egr valve on dan) and a vibration at idle. Also has a list of items he wants installed. will give updates as they come along.
Postby MrQ » Mon Dec 16, 2013 2:18 pm
Did the new egr valve clear the code?
Postby TxPlates » Tue Dec 17, 2013 12:43 pm
No.
Postby nice59fordf100 » Tue Dec 17, 2013 6:52 pm
it was part of the problem, the old one was frozen shut, because of a vac issue going to it. im in the midst of figuring that out.
Postby TxPlates » Tue Dec 17, 2013 8:46 pm
Yay so my guess was correct :p
Postby MrQ » Wed Dec 18, 2013 12:12 am
Oh great... :roll
Postby MrQ » Tue Mar 11, 2014 8:45 pm
Red is back and I have fixed a couple of things since I got it back as I just had Russell and Kris do the bare basics to get it running again.
New spark plugs
Flushed radiator and coolant
New Sway bar links
New front rotors
Mods in progress:
Powertrax Locker from Garrett on EF
Safari bar
Rear axle and front axle change out to 4.10s
Dan's Red Flyer II
Postby KF5ZXT » Tue Mar 11, 2014 9:01 pm
Nice. Which locker? Lock-Right, or No-Slip?
Postby MrQ » Fri Apr 04, 2014 5:26 pm
It WAS a no-slip. Unfortunately it was for a limited slip, not an open, and I had to send it back. the reason for this was that i was told it was for an open, so on good faith I managed to track down a 4.10 open out of a local jy and had it pulled. I actually had it completely stripped down to just the ring gear and pinion when I found that the locker wouldn't fit. After some research and a serious face palm I informed the seller that the locker he sent me was for the LS. He was genuinely surprised and offered me a full refund. With that resolved, I now need a replacement locker before I button the axle back up and swap it out with the 3.73. I have a 4.10 pig as well that needs a pinion seal replaced that I will be swapping in as well. I am planning on running full synth front and rear which will hopefully improve my mpg a bit.
In the midst of this I also picked up a Westin safari bar for Red. Granted I had to do some reinforcement and adjustment for my needs, but it came out nicely. I can actually sit on it and not bend the mounts or the bar.
My modifications. 1/4" steel from some old shackles providing support to the upper part of the bar. Still need to paint those. I also welded some of the leftover shackle to the steel pressed back up supports preventing them from bending.
And that's all for now folks! :bounce
Postby KF5ZXT » Fri Apr 04, 2014 7:36 pm
So wait, are you going with 4.10's, or 3.73's?
Postby MrQ » Fri Apr 04, 2014 11:11 pm
I am swapping in the 4.10's front and back, replacing the 3.73's.
Postby TxPlates » Sat Apr 05, 2014 1:11 pm
The rear axle you got from the trac is already a 4.10
Postby MrQ » Sat Apr 05, 2014 3:52 pm
I know, unfortunately a couple of weeks after I picked up the trac axle, Red went down for the count and in order to get her fixed again I had to sell the axle to get extra funds to get her up to Russell and Kris. This was before I got my old job back. If I had known I would have been hired back I wouldn't have sold it. :(
Postby TxPlates » Mon Apr 07, 2014 10:11 pm
Major fail.
Users browsing this forum: No registered users and 4 guests
