Demon4x4.com • View topic - 2006 Nissan Xterra Zombie Response Vehicle
Re: 2006 Nissan Xterra Zombie Response Vehicle
Postby BigTim55 » Sat Mar 30, 2013 2:11 pm
Postby TxPlates » Sat Mar 30, 2013 2:28 pm
Postby BigTim55 » Sat Mar 30, 2013 2:32 pm
Postby BigTim55 » Sat Apr 06, 2013 11:42 am
I may just have to copy this guys build :-)
http://www.thenewx.org/forum/showthread.php?t=52368
Sent from Xavier's School for Gifted Youngsters
Postby TxPlates » Sat Apr 06, 2013 4:21 pm
Postby BigTim55 » Mon Apr 08, 2013 10:41 am
If I go his route all I will have to figure out the 4wd conversion correct?
Postby KF5ZXT » Mon Apr 08, 2013 10:45 am
That, and the minor detail of the solid axle swap part. Start looking around for JK axles, you'll need both front and rear. You'll need new wheels for the new bolt pattern (5 on 4.5), so don't go buying any before then. What travel are your current coilovers? You'll probably need new ones, along with shock hoops, unless you go a more traditional coil shock route, which is a little cheaper.
Does that truck have an actual build thread somewhere, or just this for sale thread?
Postby BigTim55 » Mon Apr 08, 2013 11:02 am
Postby KF5ZXT » Mon Apr 08, 2013 11:23 am
What a lame tard.
If you look in the picture above, the part that the top of the coilover connects to, looks like an upside down U. That was welded on. Coilovers are indeed better than coils, and easier to install (if you're welding things on anyway). But they are quite a bit more expensive. I think I got my front pair for something like $900.
Here's a link to some coilover/shock hoops:
Postby TxPlates » Mon Apr 08, 2013 6:02 pm
There's a picture? LOL
Postby BigTim55 » Wed Apr 10, 2013 12:37 pm
http://www.thenewx.org/forum/showthread.php?t=62018
Postby KF5ZXT » Wed Apr 10, 2013 12:38 pm
You can't cut and paste the relevant info?
Postby TxPlates » Wed Apr 10, 2013 1:04 pm
He probably didn't copy and paste that all by himself....just saying.
Sent from you guessed it.
Postby KF5ZXT » Wed Apr 10, 2013 1:07 pm
I see those Super Duty axles for sale at pick & pulls (particularly the by Kirs) for about $500.
Postby BigTim55 » Wed Apr 10, 2013 3:15 pm
Postby KF5ZXT » Wed Apr 10, 2013 3:24 pm
One of the best ball joint axles out there from the factory. The 99-04 will be set up for leafs, 95+ for coils. If you're going coilovers, that is not important to you. There is a thread I posted on this board that links to a Pirate thread that talks about this axle. One of the main drawbacks is that it uses a metric bolt pattern (8 lug on 170mm) rather than the standard (8 lug on 6.5"). It also uses unit bearings, which are as good if not better than standard bearings, but are 10x plus more expensive to replace.
Postby KF5ZXT » Thu Jun 20, 2013 10:22 am
Postby KF5ZXT » Wed Jun 26, 2013 11:59 am
Did you get your bumper installed yet?
Postby KF5ZXT » Fri Jun 28, 2013 10:36 am
Yikes:
Postby TxPlates » Fri Jun 28, 2013 6:12 pm
That looks scary. I guess the rear bumper has been lost.
Postby BigTim55 » Sat Jun 29, 2013 8:24 pm
Yea I've seen that thread. Kinda scary. Lol. I've gone away from that board. It's gone to shit since autoguide bought it out
Sent from Xavier School for Gifted Youngsters
Postby TxPlates » Sat Jun 29, 2013 8:50 pm
So did the rear bumper go to shit as well?
"It is what it is, till it ain't anymore"
Postby BigTim55 » Sun Jun 30, 2013 12:59 pm
Lol no I have it I just haven't had a chance to install it yet
Postby KF5ZXT » Sun Jun 30, 2013 1:07 pm
Postby TxPlates » Sun Jun 30, 2013 1:54 pm
Surprise!
