Demon4x4.com • View topic - EEE's 1991 Ford Explorer
Re: Brake Upgrade, 91 Exploder
Postby TxPlates » Tue Sep 17, 2013 3:28 pm
Hell yes, can't beat savings. Maybe it'll show up as quick as the other parts you ordered.
Postby KF5ZXT » Tue Sep 17, 2013 3:39 pm
Yep, they arrived the next day.
Postby TxPlates » Tue Sep 17, 2013 4:05 pm
Well here's to hoping this corrects the current brake issues. You going to try to get them done during the week to see if you still need to take back to TAG (if they still exist)?
Re: Thoughts on this radiator?
Postby KF5ZXT » Wed Sep 18, 2013 11:03 am
Postby KF5ZXT » Tue Sep 24, 2013 10:07 pm
Taking the black truck up to TAG today after work to have them finish the hydroboost setup, mount my light bar, and maybe the rear bumper. Also some other minor things.
Postby KF5ZXT » Mon Sep 30, 2013 11:31 am
A couple other options for the radiator:
That one's a little wider and would require custom mounts, but has two waterproof electric fans. The off-road versions have deeper fans as well as performance curved blades which pull more air for that high heat/low rpm stuff we like to do. Runs about $600.
Here's a cheaper version on ebay with an integrated electric 16" fan. Doubt it's waterproof.
Of course, if I'm going to think about an engine swap, I'll have to take into consideration the inlets/outlets of the new motor.
Postby KF5ZXT » Tue Oct 29, 2013 7:12 pm
Neither of the master cylinders I brought are going to work. Dave went to get a Super Duty MC.
Postby TxPlates » Tue Oct 29, 2013 7:19 pm
That stinks, still in trac for the asked date of delivery?
Postby KF5ZXT » Tue Oct 29, 2013 7:19 pm
Yep.
Postby TxPlates » Tue Oct 29, 2013 7:22 pm
What's the difference between the ones you provided and a super duty one?
Postby KF5ZXT » Tue Oct 29, 2013 7:23 pm
Bore diameter, valving, and stroke length.
Postby TxPlates » Wed Oct 30, 2013 8:11 am
Well fingers crossed hope this works for your rig. Then you're pretty much set for the trip in Nov?
Postby KF5ZXT » Wed Oct 30, 2013 8:19 am
No, still need to replace the radiator.
Postby TxPlates » Wed Oct 30, 2013 8:25 am
Oh that's right, have you finalized a decision on one yet?
Postby KF5ZXT » Wed Oct 30, 2013 8:48 am
Probably going with this one, hoping I can get a solid three years out of it.
We'll see how much money I have left after getting back from TAG. :lol
Postby TxPlates » Wed Oct 30, 2013 10:19 am
Lol well hurry up :p
Postby KF5ZXT » Wed Oct 30, 2013 1:53 pm
I've still got a month. It shouldn't take me that long to swap out a radiator :finger
Postby KF5ZXT » Thu Oct 31, 2013 2:40 pm
Super Duty MC is a bit larger than the two I had on previously, so he's having to cut out the driver's side shock hoop and re-do it. Yay!
Postby TxPlates » Thu Oct 31, 2013 4:17 pm
Oops, still on track though time frame wise?
Postby KF5ZXT » Thu Oct 31, 2013 4:18 pm
Yep. Still plans to have it done by Tuesday/Wednesday of next week.
Postby KF5ZXT » Fri Nov 08, 2013 10:53 pm
Getting pretty cramped in there. Shimmed the Super Duty hydro boost up a few degrees so the master cylinder would clear the shock hoop. Ended up going with a Super Duty master cylinder. The pushrod still ended up being way too long. Cut it down with trial and error til it worked. Deglazed the brake pads and now everything seems good. Must have been a vacuum issue. Drove it around for a good half hour, no lockups.
Rear bumper underway. Going to cut out the stock rear crossmember now that the bumper is taking it's place. Adding some 1/2" clevis mounts and then the winch cradle behind there, with a hawse fair lead. Maybe a couple of pod led's will fit in there.
Postby TxPlates » Sat Nov 09, 2013 8:15 am
Looking good, glad the brake issue is finally cleared up.
Postby KF5ZXT » Sat Nov 09, 2013 10:14 am
Me too. Must be a serious vacuum issue with the motor.
I'm also having them make 'rub rails' along the top edge of the truck, which will tie into the light bar mount. Kinda like sliders for the top edge.
Postby TxPlates » Sat Nov 09, 2013 1:57 pm
Interesting I'll be curious to see what that looks like.
Postby KF5ZXT » Tue Nov 12, 2013 10:39 am
Made an offer for $155 on the above radiator/fan combo, which was accepted. Now, who wants to tell me how to hook that fan up? :lol
I also ordered their silicone radiator hoses. Unfortunately I had to choose between blingy red or blingy blue, so blingy red it is. I'd have preferred blingy green, personally. :lol
Anyone think I should go ahead and replace the water pump while I'm in there? If so, any recommendations?
Users browsing this forum: No registered users and 10 guests
