[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 400: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
Demon4x4.com • View topic - EEE's '00 F-250 PSD - Houston
Page 5 of 6
PostPosted: Sun Mar 17, 2013 12:10 pm
Fogs are in.
Re: EEE's '00 F-250 PSD - Houston
PostPosted: Sun Mar 17, 2013 12:38 pm
Nice, were the factory mounts already there or did you have to rig it up to fit them in? Wired in to work?
PostPosted: Sun Mar 17, 2013 4:24 pm
No, they weren't available as an option for my year, apparently. I had to get the mounts, remove the bumper and then drill holes in the bumper for the mounts, as well as clearance some of the plastic trim to get them to fit. It's mostly wired up, I'm still waiting on a rocker switch to come in the mail.
PostPosted: Sun Mar 17, 2013 5:28 pm
Going to put led bulbs in them?
Sent from you guessed it.
PostPosted: Sun Mar 17, 2013 9:42 pm
I put Silver Star 9005's in them.
PostPosted: Mon Mar 18, 2013 7:59 am
Do they have levels on the back to aim them or you going to have to do it once they're wired in so you can turn them on and do if against a wall?
PostPosted: Mon Mar 18, 2013 8:00 am
Yes to both.
PostPosted: Wed Mar 20, 2013 3:39 pm
Did you ever get the left rear door fixed ?
PostPosted: Wed Mar 20, 2013 3:40 pm
Just got in the new cable a couple days ago. Just need to install it. (Which involves drilling out some rivets).
PostPosted: Wed Mar 20, 2013 4:39 pm
Get the cable off e-bay?
PostPosted: Wed Mar 20, 2013 4:40 pm
Yes, I did.
PostPosted: Wed Mar 20, 2013 7:27 pm
Nice.
PostPosted: Sun Mar 31, 2013 11:53 am
Ok, help me out with this wiring. Lol
Should I assume that 85 = blue wire, and 86 = black wire? If that is correct, Does blue go to pin three on the switch? Pin seven on switch I'm thinking should be tapped into parking lamps, but what of pin 2?
PostPosted: Mon Apr 01, 2013 11:30 am
by nice59fordf100
Ok, here's what you need to do. First, if you look on the bottom side of the relay, the numbers will be printed on the bottom side (30, 85, 86, 87, and 87A) so you know where each wire plugs into it. Refer to figure 1
(Figure 1)
next, do the following (In no particular order):
1) Connect your ground wire to pin 86 on the relay
2) Connect the fog lamp positive wires to pin 87
3) Connect 12V hot at all times (Battery voltage) to pin 30
4) Connect PIn 85 to Pin 3 on the switch
5) Connect Pin 7 on the switch to ground
6) Connect Pin 2 to the brown wire on the turn signal pigtail (make sure this is fused)
That should be all you need to do to make it work and the switch to light up when the fogs are on. As far as your question on which pins the blue and black wire go, i cant answer that since I cant see where you plugged them into on the relay.
PostPosted: Mon Apr 01, 2013 11:34 am
Ok, I'll have to look at what pins the blue and black wire are connected to on the relay, as the relay came pre wired. Thank you sir!
PostPosted: Mon Apr 01, 2013 12:31 pm
by nice59fordf100
No problem, sorry for the delay!
PostPosted: Mon Apr 01, 2013 9:12 pm
PostPosted: Sat Apr 06, 2013 8:34 am
by nice59fordf100
Thanks parker
PostPosted: Wed Jun 05, 2013 12:46 pm
PostPosted: Wed Jun 05, 2013 5:41 pm
by nice59fordf100
wth happened?
PostPosted: Wed Jun 05, 2013 5:51 pm
Maybe you shouldn't leave burritos laying in the drivers seat that someone wants....
Sent from my iPhone 5
PostPosted: Wed Jun 05, 2013 6:11 pm
Someone tried to break into my truck last night, using a common easy access point on these model years of super duty. Lucky, I knew about this, and installed a Jimmi Jammer, which is basically a steel plate that blocks a screwdriver's entry at that point.
PostPosted: Wed Jun 05, 2013 7:12 pm
by BigTim55
You should buy a gun
Sent from my SGH-M919 using Tapatalk 2
PostPosted: Thu Jun 06, 2013 7:00 am
Gun doesn't do much good while you sleep and they break into your vehicle in the middle if the night....just saying.
PostPosted: Thu Jun 06, 2013 7:13 am
by BigTim55
