Rock Trac - 2001 Ford Explorer Sport Trac 4x4
Re: Rock Trac - 2001 Ford Explorer Sport Trac 4x4
Postby KF5ZXT » Sun Oct 20, 2013 12:17 pm
Nice. Good job figuring out some of those issues.
Blue Ribbon Coalition Lifetime Member
Sexy Evil ST wrote:Ok, I've got a new nickname for Randall... Ranger Dick!
Good, fast, cheap: pick any 2
Postby TxPlates » Tue Oct 22, 2013 10:58 am
When I was playing with the ac, I depressed the release valve and green liquid came out, any idea whAt that is?
Sexy Evil ST wrote:Shouldn't you actually offroad a truck to belong to those organizations? :finger :finger :finger
Postby KF5ZXT » Tue Oct 22, 2013 11:05 am
Freon?
Postby TxPlates » Tue Oct 22, 2013 11:06 am
Is freon lime green?
Postby KF5ZXT » Tue Oct 22, 2013 11:07 am
Coolant is...
Postby TxPlates » Tue Oct 22, 2013 11:24 am
Just asked at mechanic shop I was at and they said its the dye in the system They said its most likely the relay that's gone bad. Ill test that out by swapping with another when I get home.
Postby TexasArmadillo » Tue Oct 22, 2013 1:14 pm
UV dye is added with A/C oil. You can then use a black light to see the leaks.
Postby TxPlates » Tue Oct 22, 2013 1:36 pm
Makes sense, was scary when it sprayed out lol.
Postby Kris Guilbeaux » Tue Oct 22, 2013 6:59 pm
Yes freon is green
Postby TxPlates » Tue Oct 22, 2013 7:27 pm
Got my CB extension in today.
Postby TexasArmadillo » Tue Oct 22, 2013 9:37 pm
I hate messing with Freon. The stuff stinks.
Good job on the extension.
Postby TxPlates » Tue Oct 22, 2013 10:01 pm
Yes sir freon is messy, I'll mess with the relay tomorrow to see if that's the case. The CB extension is awesome, just need to drill a hole thought the center console to run the wires and I'm good to go.
Postby TxPlates » Wed Oct 23, 2013 8:05 pm
Progress on the CB install.
Bracket installed inside the center console.
Holes cuts in the front and rear for wires. They both look the same.
CB mounted.
Postby TxPlates » Sat Oct 26, 2013 12:20 pm
Postby KF5ZXT » Sat Oct 26, 2013 2:18 pm
Well done, sir.
Postby TxPlates » Sat Oct 26, 2013 6:06 pm
Danke.
Postby TexasArmadillo » Sun Oct 27, 2013 7:49 pm
Looks real good.
Postby TxPlates » Mon Oct 28, 2013 3:51 pm
TexasArmadillo wrote:Looks real good.
Thank you sir.
Postby TxPlates » Tue Oct 29, 2013 7:21 pm
Just dropped off at Torch Monkey Fabrication. They'll be modifying the tranny cross member and building a front bumper with fog lamp mounts tabs and a winch mount. Should be completed and ready for pick up this Saturday.
Postby TxPlates » Sat Nov 09, 2013 1:59 pm
Well as usual things did not go as planned with the trac. Just picked it up, all they were able to complete was the new cross member (at least that got done).
Postby Kris Guilbeaux » Sat Nov 09, 2013 3:18 pm
Looks good any pics of the exhaust clearance?
Postby TxPlates » Sat Nov 09, 2013 3:31 pm
I'll take one later, it's very minimal. All they did was move it over via shifting the pipe with out having to weld or anything. It's a very small clearance for the shaft. I'm betting it probably bangs against it when I wheel it, but shouldn't be a big deal.
Postby TxPlates » Sat Nov 09, 2013 4:05 pm
Notice there is a leak.
And another here Image
Postby TxPlates » Sat Nov 09, 2013 4:08 pm
I tried to get a good picture but it's leaking coolant at the hose that plugs into the bottom of the motor.
Postby Kris Guilbeaux » Sun Nov 10, 2013 12:21 pm
So you need a pan gasket and a lower radiator hose? I thought we put on new radiator hoses
