Dan's Red Flyer II
Re: Dan's Red Flyer II
Postby MrQ » Tue Apr 08, 2014 5:29 am
Yeah, no kidding.
Postby KF5ZXT » Tue Apr 08, 2014 8:11 am
Gotta do what you gotta do.
Blue Ribbon Coalition Lifetime Member
Sexy Evil ST wrote:Ok, I've got a new nickname for Randall... Ranger Dick!
Good, fast, cheap: pick any 2
Postby TxPlates » Tue Apr 08, 2014 8:22 am
Coulda sold a kidney lol
Sexy Evil ST wrote:Shouldn't you actually offroad a truck to belong to those organizations? :finger :finger :finger
Postby MrQ » Tue Apr 08, 2014 11:17 am
Was contemplating that...
Postby MrQ » Mon Apr 21, 2014 4:17 am
Got the new 4.10 rear axle in with the Spartan locker. I also filled it with royal purple oil for good measure. Did wind up having to cut off the driveshaft bolts on the old axle. For some reason heat, lubrication, and 500ft-lbs of torque could not spin those bolts. Gonna have to drop by ford to pick up some replacements.
Postby KF5ZXT » Mon Apr 21, 2014 9:02 am
Well done, sir.
Sounds like you put an impact on them and still couldn't get them loose? I guess the resident T-800 put them on there.
Postby MrQ » Tue Apr 22, 2014 2:00 pm
That is my guess. :p Had a problem with my brakes yesterday and today. Forgot to put new copper crush washers on the connections when I reinstalled the calipers. Left a nice trail of brake fluid on HWY 59. Had to call in today as my fix yesterday failed and I had no pedal this morning. FML! In any case after a brake bleed and the rear brakes are fine. The front brakes on the other hand still need to be bled, but I am afraid of rounding off the bleeders since FORD in their infinite wisdom didn't use a standard wrench size for removing them.
Postby Kris Guilbeaux » Sat May 17, 2014 8:00 am
The trick is get a socket and break the bleeder loose, then use the box end to open and close the bleeder valve
Postby MrQ » Sat Jun 21, 2014 12:08 pm
Ok finally some progress, because of the inherent stupidity of Chrysler transmission builders, the Ram's slush box went out and I was forced to get Red ready to go.
-New Rancho RS5000's all around
-New lower balljoints
-New outer tie rod end
-New 4.10 D35 with pinion seal replaced
-Finished installing the rear driveshaft bolts
-Installed new LED lights on bullbar
-Removed spare tire winch
All that's left is to install the passenger window motor and give her a good cleaning.
I am looking at getting a trailer hitch and one of those nice swing away spare tire holders for the 33 eating up my cargo space.
Randall, need to update my rig page. :D
Postby KF5ZXT » Sun Jun 22, 2014 11:33 am
Lol, will do.
