Demon4x4.com • View topic - 2006 Nissan Xterra Zombie Response Vehicle
Postby BigTim55 » Thu Apr 12, 2012 11:01 pm
This is my work in progress it is 2wd but that may change soon :twisted: I have plenty of things sitting in my garage waiting to be done, including a 3" body lift, Doug Thorley Long Tube headersImage, Doug Thorley B Pipes.
I have a AEM Brute Force intake and a Flowmaster 40 series exhaust at the moment. I plan on putting titan control arms on it with some radflo 2.5 coilovers. And maybe an ARB locker.
Postby KF5ZXT » Thu Apr 12, 2012 11:14 pm
Welcome to the board, Tim!
We have a resident 4x4 conversion expert that will probably be able to lend some expertise.
Let's set a date to throw on that body lift.
Re: 2006 Nissan Xterra Zombie Response Vehicle
Postby BigTim55 » Thu Apr 12, 2012 11:26 pm
Sounds good to me! I just have to figure out when I can make another trip down to Mo city, I know I am coming down the last weekend of April for a baby shower.
Oh I forgot my zombie response team sticker Image
Postby KF5ZXT » Fri Apr 13, 2012 7:22 am
Last weekend of April, we are having a group meeting in the Austin area (Bandit Fest thread under club runs).
Love that sticker.
Postby KF5ZXT » Fri Apr 13, 2012 9:44 am
Sorry, I'm not as familiar with XTerra's, so I'll have some questions. :)
1. Do the PRG kits not typically come with the coilovers?
2. I've read that the Titan Swap will net you 2" of extra axle width on each side. Any thoughts to what you'll do to match up the rear? Instead of wheel spacers, does a Titan rear axle plug and play? (I'm not a fan of wheel spacers - personal experience, lol)
3. The Titan swap is good for, what 3-4" of lift in the front? Are you planning on for the rear, or perhaps lift springs, such as Alcans/Old Man Emu's (which I would recommend against Add-A-Leaf's)?
4. Also - is there a reason why you prefer the Rad-Flo's over the Sway-Aways?
5. What gear ratio do you currently have in the rear? It looks like the M205 front axle (the most likely swap candidate for a 4x4 conversion, from a Nissan Titan) comes stock with a 3.36 ratio. You'll want front and rear to match, of course.
6. What size tire are you planning to run after the 3" body lift + 3-4" Titan Swap? You may want to consider reagearing for your final tire size at the same time that you put the lockers in, to save on labor costs. Have the 4.10's come out yet for the Nissan axles?
7. Any thoughts to swapping in Titan outers as well (knuckles, spindles, brakes, etc) for 1/2 ton braking? Bolt pattern would change from 6 lun on 4.5 to 6 lug on 5.5, but with bigger tires comes wider wheels in many cases. Plus, if you did the Titan rear axle at the same time, then the bolt pattern would match.
This looks like a good thread:
Postby BigTim55 » Fri Apr 13, 2012 12:51 pm
Postby KF5ZXT » Fri Apr 13, 2012 1:56 pm
Looks like the Titan Axle is sprung over, so you'd have to get new spring perches (which are cheap) to spring it under.
Correct me if I'm wrong, but are you sure you want to do the 2wd lift spindles in addition to the 3-4" PRG lift, and three inch body lift? That will put you at around 12" of total lift, which is huge (My truck has about 9")? Not to mention they'd be useless if you ever decide to convert to 4x4, and you'd have to raise the rear the extra 6 inches as well.
Postby BigTim55 » Fri Apr 13, 2012 3:55 pm
Postby TxPlates » Fri Apr 13, 2012 5:43 pm
Welcome to the group, I'm a fan of the X.
Postby BigTim55 » Fri Apr 13, 2012 5:49 pm
Postby TxPlates » Fri Apr 13, 2012 6:27 pm
Hmmmmmm who's your old neighbor?
Postby KF5ZXT » Fri Apr 13, 2012 6:28 pm
I grew up next door to Tim.
Postby TxPlates » Fri Apr 13, 2012 6:30 pm
So you assume Tim is talking about you Randall. That's awful presumptuous.
Postby KF5ZXT » Fri Apr 13, 2012 6:41 pm
Where exactly did I assume anything? I merely made a factual statement. You simply inferred what you wanted from that.
Postby BigTim55 » Fri Apr 13, 2012 7:54 pm
Randall was my old neighbor, our parents still live next to each other lol. My titan swap may be on hold for a little while, the guy who I was buying stuff from is being deployed again and won't have time to get me my parts, so I will probably go the more expensive way and get new everything!
Postby TxPlates » Fri Apr 13, 2012 8:23 pm
I did not infer anything, stop assuming lol. That sucks about the not getting the hook up parts, but new parts are always fun.
Postby BigTim55 » Mon Apr 16, 2012 9:15 pm
Now I need an explorer to fit in!
Postby TxPlates » Mon Apr 16, 2012 9:18 pm
Lol.
Postby KF5ZXT » Mon Apr 16, 2012 9:32 pm
Postby BigTim55 » Mon Apr 16, 2012 9:41 pm
Postby TxPlates » Mon Apr 16, 2012 9:55 pm
Nah stick with the explorer or something smaller. Easier on the trails, and like Randall said, explorers are a dime a dozen, easier to get parts for, and we have a kris and russ to fix them lol.
Postby KF5ZXT » Mon Apr 16, 2012 9:58 pm
Early Bronco's and Bronco II's are smaller than Explorers.
Postby TxPlates » Mon Apr 16, 2012 10:04 pm
And harder to get parts for.
Postby KF5ZXT » Mon Apr 16, 2012 10:16 pm
Bronco II's will take most explorer parts.
Postby BigTim55 » Mon Apr 16, 2012 10:29 pm
Once I get my truck where I want it I will more than likely start looking into a dedicated trail rig, but my gfs car is a piece of shit and she needs a new one so I would feel kind of bad gettin a second vehicle and her being stuck with a car that barely runs
