Page 2 of 2
Re: 91 Eddie Bauer 2dr "Goldilocks"
Wed Feb 13, 2013 2:18 pm
Shit, my factory one leaks every now and then.
Wed Feb 13, 2013 2:40 pm
by BigTim55
that sounds like something you should have a doctor check out...
Wed Feb 13, 2013 3:05 pm
Understandable, but I think more prone to leaking after market is all I'm saying.
Wed Feb 13, 2013 3:21 pm
No one's arguing that.
Wed Feb 13, 2013 4:51 pm
The design of this one is less likely to leak now. And the sunroof has a roof support built into it it's no weaker then if was factory and lastly ill have a sunshade with the new one which was missing in the old one
Wed Feb 13, 2013 5:33 pm
Sunshade for the win.
Mon Mar 04, 2013 8:28 am
by nice59fordf100
Well, made some progress on Goldie yesterday. We removed the driver door harness saturday night so we could add the following features to the truck and modify it in such a way to look as factory as possible:
Heated Puddle Lamps
One-touch Down for the window
Keyless entry keypad
Memory seat function
After stripping most of the harness, i wired in the green plug for the keypad and created a new 14-pin connector to go through the door jamb just for the features we were adding all while using the same wire colors and pins. This will make it easier for future diag if needed. Next I spliced in the one touch down module. I also repinned the white 3-pin mirror connector to be a 8-pin black plug for the heated puddle lamp style mirror. After everything was wrapped up nice and tidy, I moved to wiring in the rest of the memory seat functions.
A standard power seat in a first gen has just two wires going to the seat, Hot at all times and ground. A memory seat from a 93-97 explorer has 11 wires going to it (3 power, 2 ground, 6 for the memory switch), so of course extra work was needed to make it function properly. Having used the same wire colors in the new door jamb connector made this a snap to install.
Earlier this week, we modified the 92 Eddie Bauer seat frame to accept the memory seat wiring/driver seat module. There is a considerable difference in design between the limited and eddie bauer seat frames, so a support bracket had to be welded into the eddie bauer seat in order to house the DSM. Once that was completed, a test fit of everything was performed and Wa-la, the driver seat memory functions were operating normally as well as the puddle lamp and one touch down relay.
the next item to do is source out a 93-95 taurus keyless entry module to install in the truck so Goldie can have a factory like remote keyless entry system with factory keyfob and door keypad.
Mon Mar 04, 2013 8:54 am
Request for pic of seat modification.
Mon Mar 04, 2013 9:27 am
by nice59fordf100
When I get home tonight i can add the pictures. Here at work facebook is blocked, so i cant access the links for the pictures
Mon Mar 04, 2013 10:59 am
With the help of Russell We have started the electrical upgrades on Goldie. The goal is to get the wiring in and working before starting the body work and prepping for paint.
some of these upgrades required welding and cutting of sheet metal to allow for some of these upgrades.
Which include:
97+ power sunroof
96 Memory Seats
00 Heated Puddle lamp mirrors
Factory keyless entry with door key pad.
One touch down for the driver side window
Here is the hole that was cut in the roof
What was welded in
Although it still needs work the sunroof fits
And here is the door harness that was modified to except the new features
The puddle light working,
Mon Mar 04, 2013 11:23 am
Looks like a pretty serious undertaking. Nice job.
Mon Mar 04, 2013 1:33 pm
Were you able to find a second puddle lamp?
Sent from you guessed it.
Mon Mar 04, 2013 1:58 pm
by nice59fordf100
Not at present. But wiring up the second puddle lamp will be much easier as the heated rear glass circuit wire runs right long the passenger side floorboard. So getting the wires and pins and what not is a cake walk.
Mon Mar 04, 2013 6:40 pm
Nice.
Sun May 11, 2014 7:46 pm
So I took a trip to where Goldie is when I was in Victoria. To check the progress on slow flow. Here is how Goldie is coming along
Sun May 11, 2014 8:35 pm
Have an anticipated completion date?
'Bout time.
Wed May 14, 2014 12:32 pm
If funding and time allow I'm hoping paint will be done August
Wed May 14, 2014 3:04 pm
Sounds like you should sell some of the others to speed it along :p
Wed May 14, 2014 6:18 pm
Or get Russell back out on the street corner. $$$
Thu May 15, 2014 7:02 pm
The 2000 is for sale
