Demon4x4.com • View topic - EEE's 1991 Ford Explorer
Re: Brake Upgrade, 91 Exploder
Postby TxPlates » Sun Jul 07, 2013 6:33 pm
How'd the final result turn out?
Postby KF5ZXT » Sun Jul 07, 2013 8:45 pm
I need the following from a 2000 super duty, which did not come with mine. It says to reuse your old ones, but since I'm 're-optioning' this setup, I don't have any old ones. Autozone, O'Reilly and google searches have come up empty. Image
Postby TxPlates » Sun Jul 07, 2013 9:09 pm
Maybe BC can help?
Postby KF5ZXT » Mon Jul 15, 2013 9:50 am
Somone on Pirate has generously offered to send me the parts from his stash. :D
Postby TxPlates » Mon Jul 15, 2013 11:53 am
Excellent work. Time frame on when you'll get the parts?
Postby KF5ZXT » Mon Jul 15, 2013 12:43 pm
No idea, since he wouldn't really let me compensate him.
Postby TexasArmadillo » Mon Jul 15, 2013 7:42 pm
Send him beer. No one refuses beer.
Postby KF5ZXT » Mon Jul 15, 2013 8:12 pm
Depends on the beer.
Postby TexasArmadillo » Tue Jul 16, 2013 12:12 pm
Well yes. Natural Light will not make you any friends.
Thoughts on this radiator?
Postby KF5ZXT » Tue Aug 13, 2013 11:27 am
Think it'll be good enough for a future V8 swap?
Also, I'm thinking I'll ditch the clutch fan setup and go with a Volvo 940 electric fan at the same time.
Re: Thoughts on this radiator?
Postby Kris Guilbeaux » Tue Aug 13, 2013 12:02 pm
That's a great price I might order that to see how it would work
Postby TexasArmadillo » Tue Aug 13, 2013 12:41 pm
Electric fan for the win :-)
Postby KF5ZXT » Wed Aug 14, 2013 10:58 am
Postby Kris Guilbeaux » Wed Aug 14, 2013 12:51 pm
So they do not make two different versions of this caliper? I thought your axle was from a newer super duty...
Postby KF5ZXT » Wed Aug 14, 2013 1:04 pm
No, it is from a 1979. The Super Duty axles are ball joint. King pins are much stronger.
Postby Kris Guilbeaux » Wed Aug 14, 2013 6:40 pm
So do they make an upgraded caliper for these axles
Postby KF5ZXT » Wed Aug 14, 2013 6:48 pm
That's what I'm trying to find out.
Postby KF5ZXT » Thu Aug 22, 2013 10:52 am
Small update on the brake issue. I've successfully bypassed the ABS module, but haven't really driven it yet to test it out. I trimmed the ends off of the brake line going into the ABS module and replaced them with 3/16's male fittings, and joined them with a 3/16's union. My main concern here is finding out that my truck only had rear ABS, which means that it was likely not causing all of my brakes to lock up, which has been my problem.
Also, I (my wife, actually) recently got summoned to appear at court for a certain 'junked/abandoned' vehicle, which has been parked in my driveway; plus I drive it around a bit here and there. Obviously not abondoned, at any rate. So I look up the Missouri City, TX .gov website to find their definition of a junked/abandoned vehicle (italicized sections denote my emphasis):
* An abondoned vehicle is defined as any vehicle left unattended on the roadway for a period of 48 hours or longer.
* An abondoned vehicle is subject to towing at the expense of the owner.
* A junked vehicle is defined as any vehicle on public property for more than 72 hours that is inoperative and does not have current registration or an inspection certificate.
While I don't believe that my truck fails any of these qualifications due mainly to the use of the conjunction word 'and' in part three, I am nonetheless focused on getting this truck re-registered and inspected before the court date on September 4th. My vehicle is not on the roadway, it is in my driveway. My vehicle is not on public property, it is in my driveway. My vehicle is not inoperative, and therefore does not fulfill the AND portion of the listed qualifier in part three. It is true that it has not been registered or inspected since 2008, but since I don't drive it on the street, I don't see the problem there. The truck has been and is currently, however, registered with the Texas Parks & Wildlife as as a Texas Off Highway Vehicle.
At any rate, the next step was to add the truck to my insurance (as a 'farm' vehicle). Easy.
Next will be the registration. Should be easy enough, even though the vehicle is not registered in my name currently, thanks to my lacking the title...
And then the inspection sticker.
I also have a shiny new 2014 Texas Off Highway Vehicle Program sticker en route in the mail.
According to the requirements for Fort Bend County, a properly inspected vehicle must have the following:
1. Horn :check
2. Windshield Wipers :check, brand new, purchased in Moab.
3. Mirror :check two side mirrors. No rearview at the moment, but only two are required.
4. Steering :check
5. Seat Belts :check
6. Brakes (system) (Parking - beginning with 1960 models) - Here lie my issues.
7. Tires :check
8. Wheel Assembly :check
9. Exhaust System :check
10. Exhaust Emission System (beginning with 1968 models) :check
11. Beam Indicator (beginning with 1948 models) :check
12. Tail Lamps (2); (1) if 1959 model or earlier :check
13. Stop Lamps (2); (1) if 1959 model or earlier :check
14. License Plate Lamp (1) :check x2
15. Rear Red Reflectors (2) :check
16. Turn Signal Lamps (beginning with 1960 models) :check - had to replace the flasher and turn signal fuse, but all good now.
17. Head Lamps (2) :check, just put new shiny ones on a couple months ago.
18. Motor, Serial, or Vehicle Identification Number :check
19. Gas caps on vehicles 2-24 model years old. - :check Brand new added on in Moab after I broke my OEM one.
For #6: Aside from my brakes locking up, the brakes work (overly well), and for usually a mile or so before they lock up. Plan is to load on trailer, drive to inspection place, and offload there, to minimize the amount of time that the brakes are being used. Should be fine for a once around the shop drive to test brakes. Only other issue is the Parking Brake. Which I do have, but it is not functioning properly at the moment. My plan there is to route the emergency cable back through the firewall and attach it to the brake pedal, in effect making my parking brake a 4 wheel hydraulic disc version. . I'm going to also add a traditional mechanical brake via a floor mount that ties into my driveline brake, at some point in the near future. In the meantime, the hydraulic version should be enough for the inspectors.
Postby TexasArmadillo » Thu Aug 22, 2013 12:53 pm
Wow, sounds like you pissed off a neighbor.
Postby TxPlates » Thu Aug 22, 2013 4:43 pm
Sounds like a plan, when do you plan on trying to have it inspected?
Postby KF5ZXT » Thu Aug 22, 2013 4:46 pm
Sometime soon-ish.
Postby KF5ZXT » Mon Aug 26, 2013 11:28 am
Got the registration and new plates this morning, after jumping through a couple hoops. Also got my new 2014 Texas Off Highway sticker. Next up, inspection time.
Postby TxPlates » Mon Aug 26, 2013 4:06 pm
Now time to walk to over to the neighbors and show them the new plates, put them right in their face and say "you're welcome".
Postby KF5ZXT » Mon Aug 26, 2013 4:27 pm
You mean dissolve him in an acid bath?
Postby TxPlates » Mon Aug 26, 2013 5:03 pm
Well I thought that was a given after you said "you're welcome".
Users browsing this forum: No registered users and 26 guests
