Demon4x4.com • View topic - Dana 60 musings
Dana 60 musings
Dana 60 musings
Postby KF5ZXT » Wed May 09, 2007 1:22 pm
Ok, here is a random sampling of my train of thought:
I'm thinking of squeezing some 15" wheels on a dana 60, to save the cost of buying new beadlocks. Of course, the lug pattern would be different. Steel wheels can, however, be recentered.
Ford Dual piston calipers are huge compared to Chevy calipers and thus need a lot more grinding. 3/4" ton chevy brakes require no grinding. sells 3/4" ton caliper brackets for either the chevy/dodge knuckle, or the ford knuckle. Sound simple. I would need the Ford ones. Right?
I read that there are a couple of ways in which you can have 35 spline outer shafts. Using Chevy Spindles or grinding .6" off the end of the 35 spline stub shaft. I happen to have 35 spline stub shafts. You can use the chevy spindles either by re-drilling the ford knuckle to a 6 bolt spindle or running chevy knuckles out. I wonder which of these three options mine has? If I had to guess based on the photos below, I'd say that it has Ford knuckles on it, since the tie rod is mounted underneath the steering arm. I think. I'll have to go take some more close up shots.
You might be thinking - Why spend all that extra money just to run 15" wheels? I'm not really thinking about costs at the moment; just options. Though running the 15" wheels would mean that I would not have to buy new tires. Basically it would be a balance of replace tires and wheels versus change out the brakes, calipers, backing plate (possibly the knuckles) and recentering 5 wheels. I'd eventually like to replace the knuckles with the dedenbears anyway. It would be nice to get the right knuckles when I order them. ;) The brakes could probably stand to be replaced as well, looking at the images below. It definately needs new kingpin caps / highsteer arms.
Thoughts from the peanut gallery?
Postby JRodSA » Wed May 09, 2007 6:21 pm
:idea <--------thoughts,lol
2009 is here, Take charge, take risks, take responsibility.
Live, Laugh, & most imporant LOVE
JRodSA
Postby Michael » Wed May 09, 2007 6:41 pm
Recentered hummer H1 beadlocks. Can be had fairly inexpensively on Pirate. Sell 15" beadlocks cheaply to a friend :wink .
Or find some cheap 16x8 wheels and run the 38-13-16 swampers. Very small chance of losing the bead on a wheel that narrow. Sell 15" beadlocks cheaply to a friend :wink .
17" H2 take offs. Can be had cheaply on craigslist. Run 39-42" IROCS. Sell 15" beadlocks cheaply to a friend :wink .
Postby KF5ZXT » Wed May 09, 2007 6:49 pm
I'm sensing a pattern.... :idea
Postby KF5ZXT » Wed Mar 12, 2008 9:57 am
Double shear D60 High steer arms:
Included in Kit:
2 Double Shear high steer Arms with Grease Zerk and clamping bolt
8 200,000 psi CrMo ARP high strength studs[/list]
8 Custom machined self centering enclosed nuts
2 Kingpin spring / teflon bushing rebuild kits
8 7/8" to 5/8" High Misalignment spacers (proprietary to application)
2 RH QA1 XMR-14 CrMo rod ends & Jam nuts
2 LH QA1 XMR-14 CrMo rod ends & Jam nuts
2 Gr. 8 socket cap bolts for top double shear piece and optional Dedenbear 5 stud knuckle support [/list][/list]
Postby Kris Guilbeaux » Wed Mar 12, 2008 10:41 am
Postby KF5ZXT » Wed Mar 12, 2008 10:50 am
Postby SVO » Wed Mar 12, 2008 11:32 am
Postby KF5ZXT » Wed Mar 12, 2008 12:08 pm
Tires or Axles? ;)
Postby Justin Klare » Wed Mar 12, 2008 4:22 pm
Postby KF5ZXT » Wed Mar 12, 2008 4:55 pm
Postby SVO » Wed Mar 12, 2008 5:18 pm
Postby KF5ZXT » Wed Mar 12, 2008 5:20 pm
Postby KF5ZXT » Wed Mar 12, 2008 5:23 pm
Postby SVO » Wed Mar 12, 2008 5:29 pm
Postby Justin Klare » Wed Mar 12, 2008 8:59 pm
how much did you pay for them? and is michael still getting your beadlocks?
