Demon4x4.com • View topic - Best Air Filter
Best Air Filter
Best Air Filter
Postby SVO » Tue Feb 19, 2008 8:55 am
So you think that the Briggs & Stratton replacement air fiilter is worthy, or is ther a better or comparable aftermarket one out there that might even net me a 1/4 extra hp?
What about removing the foam dust filter cover on the filter for a bit of extra torque??
Postby Kris Guilbeaux » Wed Feb 20, 2008 1:20 am
Stick with the briggs filters. they filter the air better. I think you would just hurt your HP with removing the pre-filter. Because you will be sucking the grass clippings to the paper filter causing restriction...
What do you think...
Postby SVO » Wed Feb 20, 2008 10:46 am
I wish I could find a K&N that would fit the carb, at least I know I could clean it and reuse it, and still gain some HP.
You know I guess I could make a manifold to run dual single barrel carbs on that B&S I/C, and I do know that make stroker kits for them too.
Postby Stang Girl » Wed Feb 20, 2008 5:46 pm
I thought you could use a K&N for the mower....wouldn't it just be the ones that they use on "ricer" cars? :idea
Postby Kris Guilbeaux » Thu Feb 21, 2008 11:27 am
Some Briggs Motors also have a Hardened Crackshafts. Those would be Ideal for a Stroker rebuild.
Postby Michael » Fri Feb 22, 2008 10:25 am
Users browsing this forum: No registered users and 10 guests
