Demon4x4.com • View topic - V8 Swap estimations
Page 1 of 2
V8 Swap estimations
PostPosted: Thu Jun 12, 2014 8:08 am
So I have a lot of v-8 swap questions coming to me. I have been working on v-8 swap estimations for a Future Bandit Customs projects. So I figured I would compile a list of parts needed and their estimated costs.
Motor (used) $450.00
Transmission (Used) $250.00
303 Cam (optional) $200.00
Radiator HD $200.00
Engine bay harness $150.00
Oil pan $200.00
flywheel or flexplate $100.00
PCM $50.00
Clutch or TC $205.00
motor mounts $200.00
Transmission Rebuild $600.00
Adapter Or t-case $400.00
Custom AC lines $150.00
Accumulator $40.00
freon $36.00
Remote oil filter $80.00
Custom Exhaust $800.00
Reflashing the PCM (optional) $400.00
Gaskets and seals $500.00
Parts alone $5011.00
Labor on a project like this would range in the $3000-$3500 price range.
This really gives a good idea of what a v-8 swap what it would take to do this and how hard it would hurt your back pocket. Even as a DYI person its still costs in parts.
Re: V8 Swap estimations
PostPosted: Thu Jun 12, 2014 8:15 am
Nice thread. Are the prices on the motor from what your pick and pull charges for them, or just what you see them go for?
PostPosted: Thu Jun 12, 2014 8:21 am
That's the prices you find at our yards in Austin tx. I seen them go for more and less.
PostPosted: Sun Jun 15, 2014 11:32 am
by MrQ
Swaps on first gens or second?
PostPosted: Sun Jun 15, 2014 12:54 pm
I'd say the estimations are pretty close for being either a first gen or second gen.
PostPosted: Sun Jun 15, 2014 9:11 pm
by MrQ
No I think this is for a first gen. A second gen is almost drag and drop, no custom exhaust or a/c lines, hd radiator or $200 for motor mounts.
PostPosted: Mon Jun 16, 2014 6:16 pm
Guess we'll never know since Kris isn't responding....lol
PostPosted: Tue Jun 17, 2014 10:44 am
Yes a v8 on a 2nd gen is cheaper. This is for 1st gens. If you get a donar truck it's even better.
PostPosted: Tue Jun 17, 2014 5:04 pm
by MrQ
Personally I would rather put a 1" BL on a first gen and throw a SOHC in, no new computer and all you will need is the M5OD-R2 manual and some exhaust setup and boom you have added 50 horses!
PostPosted: Wed Jun 18, 2014 11:16 am
Yeah, but you'd have what most people consider to be a less reliable motor.
PostPosted: Wed Jun 18, 2014 1:14 pm
by MrQ
Some people, once the guides are replaced the SOHC lasts as long if not longer than the OHV.
PostPosted: Wed Jun 18, 2014 1:31 pm
The sohc is not unreliable. It's more fuel efficient. But less available hp add ons
PostPosted: Wed Jun 18, 2014 1:35 pm
If I'm doing a V6 swap, it's going to be a 4.3.
PostPosted: Wed Jun 18, 2014 1:36 pm
The Chevy 4.3?
PostPosted: Wed Jun 18, 2014 1:37 pm
That's the one.
PostPosted: Wed Jun 18, 2014 1:44 pm
Good for mounting your trans to it. High hp But not much on torque
PostPosted: Wed Jun 18, 2014 2:10 pm
They are pretty comparable from the info I've found. The SOHC at 254 ft lbs, and the 4.3 at 260. It also has some actual aftermarket support. The 5.0 has 280 ft lbs, but weighs more.
PostPosted: Wed Jun 18, 2014 2:19 pm
Then why go the 4.3 when either bolt up to your trans. And the sohc would be a cheaper install
PostPosted: Wed Jun 18, 2014 2:23 pm
PostPosted: Wed Jun 18, 2014 4:26 pm
So you would spend $1000s more in fabrication to make a marginally better motor work for a little more aftermarket support. Doesn't seam quite worth it to me.
PostPosted: Wed Jun 18, 2014 4:43 pm
To the first part, yes, though partly because I find the use of 'marginally' and 'little more,' which, though obviously ambiguous and unquantifiable as terms, to be inaccurate in this case.
PostPosted: Wed Jun 18, 2014 10:15 pm
Have you ever driven a 4.3 Chevy? I have personally I would keep my ohv before going with a 4.3
PostPosted: Thu Jun 19, 2014 7:37 am
Just go diesel.
PostPosted: Thu Jun 19, 2014 7:46 am
Parker is right. The money you would waste on that 4.3 might as well get you a 4bt since money isnt an issue. Plus I am sure I could get it done faster then TAG
PostPosted: Thu Jun 19, 2014 7:48 am
