Demon4x4.com • View topic - spring over parts for The monster
Postby Kris Guilbeaux » Tue Oct 29, 2002 11:31 pm
I cant seam to find the Links to the Spring over parts I need can one of you guys help me out here.<br><br>Kris <p></p><i></i>
Re: spring over parts for The monster
Postby KF5ZXT » Tue Oct 29, 2002 11:40 pm
<!--EZCODE LINK START--><a href="http://mountainoffroad.com">mountainoffroad.com</a><!--EZCODE LINK END--> <p></p><i>Edited by: <A HREF=http://pub7.ezboard.com/bdemon4x4.showUserPublicProfile?gid=demon4x4>Demon4x4</A> at: 10/29/02 10:41:26 pm<br></i>
Postby Kris Guilbeaux » Thu Oct 31, 2002 12:44 am
Any one know which Size axle tube is on an 8.8 and which one is the better shiock mount to use?<br><br> <p></p><i></i>
Postby Michael » Thu Oct 31, 2002 12:38 pm
I want to say 3.25" but I'm not sure. Use the shocl mount with the post mount on it. The other type which Randall and I have will cause the shocks to bind, limiting travel. <p></p><i></i>
Postby Kris Guilbeaux » Thu Oct 31, 2002 4:41 pm
Ummm which shock mounts are those? Also what is the part number on the Shock yall are running. I need Shocks as well. <p></p><i></i>
Postby Michael » Thu Oct 31, 2002 6:14 pm
Shock Mount 98201<br><br>I don't know my shock number off hand, but it is too short anyway. The best thing is to get your shock mounts on and then flex and measure. FWIW I am not going with Ranchos my next time out. They are a little unimpressive too me, on both the Ex and the F250. I may try bilsteins or doeshtech (not spelled right <!--EZCODE EMOTICON START :rolleyes --><img src=http://www.ezboard.com/images/emoticons/eyes.gif ALT=":rolleyes"><!--EZCODE EMOTICON END--> ) The new 9 speed Ranchos may be good, I haven't heard anything about them yet. <p></p><i></i>
Postby Kris Guilbeaux » Thu Oct 31, 2002 8:39 pm
Well since I would need Welding skills to set it up any volunteers(with welders)? <br> <p></p><i></i>
Postby KF5ZXT » Fri Nov 01, 2002 12:37 am
I have 9112's front and rear. Yes, it is a 3.25" tube. I like my Rancho's. I think they are pretty good for a cheap ass shock. <p></p><i></i>
Welder?
Postby CHH777 » Fri Nov 01, 2002 2:35 pm
Kris,<br><br>If you can make it up to my work I'll weld 'em on for ya. We're off I-45 @ Rayford Sawdust... <p></p><i></i>
CHH777
Postby Michael » Fri Nov 01, 2002 9:54 pm
Kris I would be happy to help you get everything lined up and tacked into place for the spring perches. I don't trust my welding skills with your safety in that area. After you get the axle under the truck I'll be glad to weld the shock mounts on for you. <p></p><i></i>
Postby Kris Guilbeaux » Mon Nov 04, 2002 6:23 pm
Michael,<br><br>I ordered the parts from Mountain off-road. Since you know a bit more then I do on this Stuff. Could I have the Perched welded on before installing the Axle. Just having them welded on the Other side of the Stock ones. If I can do that I can have the Perches done then install the Shock mount after getting the axle back in the truck.<br><br>or would have cause pinion angle problems?<br><br>The Axles are getting regeared right now. Sould have them back by the end of the week.<br><br> <p></p><i></i>
Postby KF5ZXT » Mon Nov 04, 2002 6:32 pm
I would put the axle on the truck and bolt your spring hangers down onto the perches, after correctly setting your pinion angle, and then have it welded on. <br>I did this to mine and then drove it to a shop to have it welded. I tightened the hell out of those ubolts, and drove slow, but you get the idea. <p></p><i></i>
Postby Michael » Mon Nov 04, 2002 11:58 pm
Since you are running a nonCV drive shaft you want the pinion angle to be the same as the Tcase output, ie. parallel. Which should be the way it came factory. You should be able to have them weld the new perches on parallel to the old ones and be fine. This is what it looks like was done to mine. The old and new mounts are parallel, more or less. A 4 door shaft is long enough to not vibrate if the angles are not dead on. Shock mounts can be done at any time, but I reccomend doing them with the axle in the truck to get the angles right. <p></p><i></i>
Postby Kris Guilbeaux » Fri Nov 08, 2002 6:49 pm
I got the Axles back today and my spring over parts came as well. The Shock mounts are too small and would have to be modified to would on the bigger axle tube. I am going to use the shock mount bolt that came on the Weld on shock mounts and attach them via the old sway bar brackets. By doing this I raise the shock mount a bit higher and I would get the binding either. I plan to bolt up the axle then drive it slowly to a 4x4 or blacksmith to have them welded on. <p></p><i></i>
Postby Kris Guilbeaux » Tue Nov 12, 2002 9:51 pm
its getting there<br><br><br><!--EZCODE IMAGE START--><img src="http://www.explorerforum.com/data/2/97axlein.jpg"/><!--EZCODE IMAGE END--><br><br><!--EZCODE IMAGE START--><img src="http://www.explorerforum.com/data/2/97brakes.jpg"/><!--EZCODE IMAGE END--> <p></p><i></i>
Postby Kris Guilbeaux » Thu Nov 14, 2002 7:16 pm
I took the X to the blacksmith today to have my Welding done. It kinda helped that the guy that did the work builds 4x4s for fun as well. He also figured a way to use the Shock mounts from mountain off-road. <p></p><i></i>
Postby KF5ZXT » Sat Nov 16, 2002 11:14 am
what did he have to do to them? <p></p><i></i>
Postby Kris Guilbeaux » Sat Nov 16, 2002 4:08 pm
he had to cut off part of it and grind it some as well. It looks nice.<br><br><!--EZCODE IMAGE START--><img src="http://www.explorerforum.com/data/2/97axleswap4.jpg"/><!--EZCODE IMAGE END--> <p></p><i></i>
Postby Michael » Sat Nov 16, 2002 9:48 pm
looking good Kris. Do those shock mounts hang below the axle tube. It looks like they are close enough to the diff to be protected, but I'm not sure I like em below the axle. <p></p><i></i>
Postby Kris Guilbeaux » Sun Nov 17, 2002 2:22 pm
With the brake hard line in the way it would have been hard to put them up top. If I have any problem with this set up I am sure I can change it. The guy that set up the weld said the way it is set up it would take more then 7000 lbs. of pressure to break them off. I am sure I will end up breaking them one day though. I drove the truck last night but besides the fact it is shaking very bad the Truck has much better braking and the 5.13s are really nice as well. <p></p><i></i>
Postby Kris Guilbeaux » Sun Nov 17, 2002 2:28 pm
here is a better picture of it all.<br><br><!--EZCODE IMAGE START--><img src="http://www.explorerforum.com/data/2/97setup.jpg"/><!--EZCODE IMAGE END--> <p></p><i></i>
Users browsing this forum: No registered users and 8 guests
