by KF5ZXT » Wed Jul 09, 2003 6:44 pm
If you're looking to get the lift new, the cheapest place that I found it back when I did my 5.5" superlift was at <!--EZCODE LINK START--><a href="http://tyres1.com">tyres1.com</a><!--EZCODE LINK END--> but it doesn't look like they have skyjacker.<br><br>I'd order it without shocks and get some Rancho RS9000's so that you won't need sway bars. It comes with drop brackets, drop pitman arm, coil springs, sway bar drop brackets, shocks, and SOA axle perches. The shocks are pretty much junk though. Tyres1 has the superlift kit for 645 with shocks, you'll have to call and ask the price without. Also get the extended brakelines. I'll get the part numbers for the Rancho shocks that I used with my 5.5 lift when I get home. You may want to measure for yourself, but at least it will give you a starting number.<br><br>If you need help with the install, I wouldn't mind lending a wrench or two <!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/images/emoticons/wink.gif ALT=";)"><!--EZCODE EMOTICON END--> <br><br>Oh yeah, I would also recommend extended radius arms, but they can always be added on later. SkyJacker arms are better than superlift. <p></p><i>Edited by: <A HREF=http://pub182.ezboard.com/bdemon4x4.showUserPublicProfile?gid=demon4x4>Demon4x4</A> at: 7/9/03 7:53 pm<br></i>
