Demon4x4.com • View topic - 4" Springs
4" Springs
4" Springs
Postby SVO » Fri Jul 25, 2003 9:38 am
So what would happen if I put 4" springs in the Navajo, with 5deg. ecentrics?? <!--EZCODE EMOTICON START >D --><img src=http://www.ezboard.com/images/emoticons/grin.gif ALT=" >D"><!--EZCODE EMOTICON END--> <p></p><i></i>
Re: 4" Springs
Postby KF5ZXT » Fri Jul 25, 2003 8:10 pm
what the hell is 5deg. ecentrics? <p></p><i></i>
Re: 4" Springs
Postby SVO » Sat Jul 26, 2003 9:33 pm
It allows you to adjust +/- camber.<br>Stock it's either non-ajustable or only 3deg. <p></p><i>Edited by: <A HREF=http://pub182.ezboard.com/bdemon4x4.showUserPublicProfile?gid=specialvehicleoperator>Special Vehicle Operator</A> at: 7/26/03 10:33 pm<br></i>
Re: 4" Springs
Postby SVO » Sun Jul 27, 2003 8:35 am
Basically it's an upper ball joint that has an off-center point bushing that can be turned to allow for positive and/or negitive camber settings to properly aline the wheel for proper tire wear and handling charachteristics.<br><br>Without these, installing 4" spings might push the wheels (TTB arms) down at such an angle that there would be too much positive camber ( \ / ) that you would get twitchy handling and horrible outside tire wear, but with the escentric you would be able to adjust camber setings where you could at least get a "0" deg camber (strtaight up and down ) setting to keep tire wear to a minimum, where as you really need just a smidge of negitive camber ( / \ ) to get controllable/predictable handling and good tire wear.<br><br><br>I guess what I was looking for is can I skate around on a budget and buy these springs that have been offered to me and install them with a set of 4dr rear springs with shackles to give myself enough lift to fit 32" tires under my rig, or can I use the 96' F250 spring spacers (and my stocksprings) and rear 4dr springs and shakles to get approximately 2" of lift to fit the 32" tires under there to get a estimated 4" of more ground clearance to get a better break over angle.<br><br>This is something I will need when going to Moab for the trail I have previouly run in a stock Wrangler Jeep.<br><br>As I can remember and watching the "in Jeep" vid we took, to determine that there will be some issuse about passing (getting over) about 3 certian areas that I know I will not make in my stock ride highth Navajo, remeber I'm on a serious budget right now (with medical bills and my regular bills) trying to make sure I can pull the Moab trip off.<br>And as soon as I get back and sell my Caddy I can afford to go out and buy the proper lift kit from Skyjacker and do it the right way.<br><br>If you or anyone you know could help in this area it would be greatly appreciated, the main reason also is that I can't get (with just the 4" spring replacement) a "0" degree camber adjustment will prolly eat the tires out either before I get to Moab or at least will prolly eat them out beofre I get back, this would make for a long suck ass trip and more monies I can't afford to spend. <!--EZCODE EMOTICON START :\ --><img src=http://www.ezboard.com/images/emoticons/ohwell.gif ALT=":\"><!--EZCODE EMOTICON END--> <br><br><br>Oh and what about shocks?<br>Will the stock ones work or am I just barking up a tree that I'll never get into? <p></p><i>Edited by: <A HREF=http://pub182.ezboard.com/bdemon4x4.showUserPublicProfile?gid=specialvehicleoperator>Special Vehicle Operator</A> at: 7/27/03 9:44 am<br></i>
Re: 4" Springs
Postby KF5ZXT » Sun Jul 27, 2003 10:57 am
Ok, I got you. I think that with 4" springs in the front and only 1.5" lift shackles in the rear you'll be a little lopsided. I don't think that even 5 degree ecentrics will even closely line up the front tires enough to be driveable. I would use the spacers in conjunction with the shackles, that should still be alignable, I see people do that all the time. That should give you enough room for the 32's, but you may have to take off the stock navajo tupperware to avoid rubbing, especially in the front.<br>And if you need help just let us know. <p></p><i></i>
Re: 4" Springs
Postby SVO » Sun Jul 27, 2003 12:47 pm
Cool, that helps out a lot, so I'll order the coil spacers for the 96' F150 and install them with new longer bolts.<br><br>But how huch lift does the 4rd springs give you, still planning to use shackles though.<br><br>Or do the 4dr springs not lift at all just help give extra support? <p></p><i></i>
Re: 4" Springs
Postby KF5ZXT » Sun Jul 27, 2003 12:58 pm
I would not expect them to lift you more than a 1/2" -1", if anything at all. I think they are designed for extra load carrying capacity. But the 2 door is obviously lighter than the 4 door, so you may get an inch out of them. <p></p><i></i>
Re: 4" Springs
Postby Kris Guilbeaux » Sun Jul 27, 2003 7:49 pm
On an Early 2dr dont expect much lift the 2dr. springs on the 91-94 Explorers/Navajos were much more stiff. I have 2.dr springs on my 4dr. and woud really cant tell the difference.<br><br> <p></p><i></i>
Users browsing this forum: No registered users and 8 guests
