Demon4x4.com • View topic - Reaper's Rear gets some work!
Postby Stang Girl » Thu Aug 31, 2006 2:48 pm
Jeff started working on Reaper last night to fix his leaky pinion seal and to replace the pinion and carrier bearings.
Pretty colors on the lugs...
Wiping down the shaft :shock
Pulling out the other shaft
Removing the pinion
Isn't it pretty?
Ok, Jeff had to take the bearings to work to press them out and to press the new ones in. The gears and axle shafts look to be fine, so we are not exactly sure what is going on, but hopefully this will fix whatever issues we are having.
Take more pics as Reaper gets put back together. :wink
Postby FROADER » Thu Aug 31, 2006 2:57 pm
Will the garage cam be live?
Colin
:froader
FROADER
Postby Stang Girl » Thu Aug 31, 2006 3:07 pm
Yeah, but use John's link that is posted under the "On-Topic" on the bottom of the screen for the garage cam. :wink
Re: Reaper's Rear gets some work!
Postby KF5ZXT » Thu Aug 31, 2006 3:09 pm
Postby Stang Girl » Thu Aug 31, 2006 3:40 pm
Postby XanaDorn » Thu Aug 31, 2006 3:49 pm
No, you can't borrow my car!
XanaDorn
Postby section525 » Thu Aug 31, 2006 3:59 pm
section525
Postby Stang Girl » Thu Aug 31, 2006 4:00 pm
Postby Stang Girl » Thu Aug 31, 2006 4:03 pm
Postby XanaDorn » Thu Aug 31, 2006 4:12 pm
XanaDorn
Postby section525 » Thu Aug 31, 2006 4:38 pm
:bs
section525
Postby KF5ZXT » Thu Aug 31, 2006 4:44 pm
Postby Stang Girl » Tue Sep 05, 2006 1:58 pm
Well, our camera died when Jeff and Zavaral were putting Reaper back together so no pics. However, when the tires were going back on, Zavaral noticed something seriously wrong with my right rear tire....the tire is fixing to shred the tread. :o
Ok, so first, Jeff tells me not to go over 70 mph. :o Next, Jeff finds some used Kuhmos on Craigslist...I call. Guy tells me that he bought them for his Firehawk to use at the dragstrip. They are used, but pretty much in new condition, plenty of tread left. Ok, so Babygirl (Brandy) and I drive to Georgetown to pick them up. They are more than new, you can tell the wear pattern from which side of the car they were on, however, there is still plenty of tread and I got them for pretty cheap considering. I am going after work today to see Zavaral to have them mounted and balanced.
Did I mention that they are 275/?/R17? Big ole fatty tires on the back compared to my 235s right now. :twisted:
Postby KF5ZXT » Tue Sep 05, 2006 2:07 pm
So is that where the vibration was coming from then?
Postby FROADER » Tue Sep 05, 2006 2:11 pm
Hopefully that's the probelm.
Those 275s will look mean on there compared to the 235s! :twisted:
Colin
:froader
FROADER
Postby Stang Girl » Tue Sep 05, 2006 2:24 pm
Postby Stang Girl » Tue Sep 05, 2006 2:25 pm
Postby Stang Girl » Wed Sep 06, 2006 1:03 pm
Postby KF5ZXT » Wed Sep 06, 2006 1:12 pm
Postby Stang Girl » Wed Sep 06, 2006 1:14 pm
Postby XanaDorn » Wed Sep 06, 2006 1:55 pm
XanaDorn
Postby KF5ZXT » Wed Sep 06, 2006 2:13 pm
Postby XanaDorn » Wed Sep 06, 2006 2:40 pm
XanaDorn
Users browsing this forum: No registered users and 13 guests
