Demon4x4.com • View topic - Xterra SAS 4wd conversion
Re: Xterra SAS 4wd conversion
Postby BigTim55 » Thu Sep 12, 2013 5:15 pm
Postby BigTim55 » Wed Sep 25, 2013 8:45 pm
So I have decided to go the divorced transfer case route. Randall suggested the np205 so I am on the hunt for one now. I think I may have found one on Craigslist
Sent from Xavier School for Gifted Youngsters
Postby KF5ZXT » Wed Sep 25, 2013 9:18 pm
Since it's divorced, it doesn't really matter if it's driver's drop or passenger drop, so long as the front axle you get matches it. If you're thinking you're going to go stock Xterra stuff in the front, even temporarily, you'll want driver's drop. The NP205 comes in both, driver's drop for Ford, passenger drop for Chevy.
Postby BigTim55 » Wed Sep 25, 2013 9:28 pm
Postby KF5ZXT » Wed Sep 25, 2013 9:33 pm
Yessir, they are.
Postby BigTim55 » Mon Sep 30, 2013 7:02 pm
Ok so I'm thinking Rubicon front and rears for my SAS. Opinions?
Postby KF5ZXT » Mon Sep 30, 2013 7:11 pm
I thought you wanted full width?
Postby BigTim55 » Mon Sep 30, 2013 7:14 pm
Postby KF5ZXT » Mon Sep 30, 2013 7:16 pm
Mid size: narrower, can fit more easily in and around certain obstacles.
Full width: Better lateral stability.
For full width you could do super duty axles front and rear, I'm pretty sure they are set up for abs.
For narrow width, the jk axles are a good choice. Might be spendy.
Postby BigTim55 » Mon Sep 30, 2013 7:32 pm
Yea they are spendy. 2k an axle
Postby KF5ZXT » Tue Oct 01, 2013 9:34 am
Should you decide that full width is for you, you can EASILY get both Super Duty axles for less than one JK axle. Either set is going to require you to buy new wheels, as they each have different bolt patterns than your current set-up. Now, not all Super Duty's have front and rear ABS, so you'll want to make double sure on the set you purchase (again, if you decide on full width). The 05+ all have 35 spline outer axle shafts, bigger ring and pinion, and bigger brakes than the 99-04 axles, plus they are already set up for coil springs (rather than leafs).
A good read here:
Postby KF5ZXT » Tue Oct 01, 2013 10:49 am
Postby BigTim55 » Tue Oct 01, 2013 11:16 am
Postby BigTim55 » Tue Oct 01, 2013 11:18 am
The shipping would kill me tho. Hmmm I'll have to figure something out
Postby BigTim55 » Tue Oct 01, 2013 11:24 am
But it would still be cheaper than the rubicon axles
Postby KF5ZXT » Tue Oct 01, 2013 11:42 am
Yes, even with shipping of $600, you're still looking at both for the price of one JK axle. Or, you could just drive up to TN and get them yourself. :lol
Also, I'm sure there are some around locally.
Postby BigTim55 » Tue Oct 01, 2013 11:50 am
Postby KF5ZXT » Tue Oct 01, 2013 11:51 am
I don't know, after my fuel and modest hourly wage, you'd probably be better off having them shipped. :finger
Postby BigTim55 » Tue Oct 01, 2013 12:03 pm
Postby KF5ZXT » Tue Oct 01, 2013 12:05 pm
Previous
Users browsing this forum: No registered users and 6 guests
