Demon4x4.com • View topic - Rock Trac SAS
Rock Trac SAS
Re: Rock Trac SAS
Postby TexasArmadillo » Thu Aug 15, 2013 4:02 pm
When are you going to test the flex?
Re: Rock Trac SAS
Postby KF5ZXT » Thu Aug 15, 2013 4:03 pm
Waiting for the Audi to get home...
Re: Rock Trac SAS
Postby TxPlates » Thu Aug 15, 2013 5:05 pm
Lolugh, Maria took the Audi today. Trac is over at kris' now.
Re: Rock Trac SAS
Postby KF5ZXT » Thu Aug 15, 2013 5:06 pm
Electrical issues getting sorted?
Re: Rock Trac SAS
Postby TxPlates » Thu Aug 15, 2013 7:24 pm
Yes sir, Kris and Russell will work on that, then we'll plan a weekend for us all to do our monthly meeting at Kris' to finish up the rest. Kris is off at the end of the month, that work?
Re: Rock Trac SAS
Postby Kris Guilbeaux » Fri Aug 16, 2013 10:34 am
Here is the exhaust and pinion clearance
Re: Rock Trac SAS
Postby KF5ZXT » Fri Aug 16, 2013 10:35 am
Hmm. Might be time for custom high flow exhaust.
Re: Rock Trac SAS
Postby Kris Guilbeaux » Fri Aug 16, 2013 12:07 pm
I was thinking some on this could be corrected with different degree wedges? What are your thoughts Randall?
Re: Rock Trac SAS
Postby KF5ZXT » Fri Aug 16, 2013 12:14 pm
Sure, I included some other degreed wedges in the box in the back seat. Those are usually meant to set caster, though.
Re: Rock Trac SAS
Postby Kris Guilbeaux » Fri Aug 16, 2013 1:04 pm
The ones you sent I believe where installed
Re: Rock Trac SAS
Postby KF5ZXT » Fri Aug 16, 2013 1:32 pm
I sent three sets, the 7 degree that I used, and two others in the box.
Re: Rock Trac SAS
Postby Kris Guilbeaux » Sat Aug 17, 2013 7:12 pm
Um I didn't see any in the back seat but ill look again...
Re: Rock Trac SAS
Postby KF5ZXT » Sat Aug 17, 2013 10:15 pm
So no energy suspension box?
Re: Rock Trac SAS
Postby TxPlates » Sun Aug 18, 2013 8:23 am
Re: Rock Trac SAS
Postby Kris Guilbeaux » Sun Aug 18, 2013 9:40 am
Honestly I think the pinion angle isn't correct as it is I think it need to come down.
Re: Rock Trac SAS
Postby TxPlates » Sun Aug 18, 2013 7:01 pm
Re: Rock Trac SAS
Postby TxPlates » Sat Aug 31, 2013 5:05 pm
Working on swapping the rear axle. Needs new brake lines as the tracs don't match up to the first gen.
Re: Rock Trac SAS
Postby KF5ZXT » Sat Aug 31, 2013 5:08 pm
Would an adapter work, or are the lines too short?
Re: Rock Trac SAS
Postby TxPlates » Sat Aug 31, 2013 6:57 pm
They're also too short.
Re: Rock Trac SAS
Postby KF5ZXT » Tue Sep 03, 2013 10:53 am
Any updates on the rear end/brakelines? After that is the plan to modify the trans crossmember, or take to exhaust shop to see what can be done about the y-pipe?
How about the wiring for the t-case?
Re: Rock Trac SAS
Postby TxPlates » Tue Sep 03, 2013 11:55 am
Kris sent a message yesterday stating the rear brake lines were swapped out.
Russell is working in the issue with it not going into 4low.
I emailed torch monkey about the cross member, waiting on a reply from them.
Ill take it to an exhaust shop when I bring it home to see what can be done before I take it back to torch monkey for the cross member.
Users browsing this forum: No registered users and 4 guests
