Demon4x4.com • View topic - Plan B, Part II
Plan B, Part II
Re: Plan B
Postby KF5ZXT » Fri Oct 19, 2012 4:06 pm
Sounds boring. Plus, I don't really care for body lifts.
Re: Plan B
Postby TxPlates » Fri Oct 19, 2012 4:12 pm
That's funny, cause they don't care for you either.
Re: Plan B
Postby KF5ZXT » Fri Oct 19, 2012 4:15 pm
Good, then it's settled.
Re: Plan B
Postby TxPlates » Fri Oct 19, 2012 4:26 pm
So you're spare rig will be wheeling some 29" tires?
Re: Plan B
Postby KF5ZXT » Fri Oct 19, 2012 4:30 pm
No. I plan for this rig to be Core Eligible ().
Ideally it would share a spare with my other'n.
Another bonus to this project is that I would have an extra on hand for other people that don't have a rig, that might be interested in trying out the sport. I'd like to get my brother out there, for example. Which was why I started the project a while back.
Re: Plan B
Postby TxPlates » Fri Oct 19, 2012 4:32 pm
Well then you're not keeping it simple, you're having to fab up some suspension and what not to fit those big tires.
Re: Plan B
Postby KF5ZXT » Fri Oct 19, 2012 4:34 pm
Nah, much simpler than the other'n. Leaf springs vs. links, for example; or keeping a TTB that basically bolts in. Much simpler.
Re: Plan B
Postby TxPlates » Sat Oct 20, 2012 11:21 am
So have you started looking for this other rig?
Re: Plan B
Postby KF5ZXT » Sat Oct 20, 2012 12:04 pm
Just for pricing mostly. Like I said, I won't likely be starting this project til mid 2013
Re: Plan B
Postby TxPlates » Sat Oct 20, 2012 12:23 pm
Isn't the world suppose to end in 2012?
Re: Plan B
Postby KF5ZXT » Sat Oct 20, 2012 1:33 pm
Don't be scurred
Re: Plan B
Postby TxPlates » Sat Oct 20, 2012 1:37 pm
Well death does scare me, but regardless. If the world ends in 2012, no point in planning something for 2013.
Re: Plan B
Postby KF5ZXT » Tue Oct 23, 2012 9:59 am
No point in not planning it, for when you are shown to be wrong. :finger
As far as keeping things simple, I have taken that to mind and will concede to a point. To that end, I think I will amend the plan from:
1996 5.0 explorer frame & drivetrain
AWD to Manual T-Case swap
Ranger Cab swap
to:
94-97 4x4 Ford Ranger single cab short bed with 4.0L and possible Manual T-Case swap
And thus have to worry only about suspension mods and rear bed delete.
Front Axle
I'm leaning full width Dana 44. Of which type, I have not yet decided. :D
This rig will be much lighter in weight than t'other'n, so the D44 should be fine.
F250 Dana 44 solid axle on leafs might be the easiest, and would be 8 lug (3/4 ton).
F150 Dana 44 (1/2 ton) on coils/coilovers might be a little more interesting though. And, I don't think it would be all that hard.
I happen to have some of these required items in the garage already (Chevy 44 brake caliper brackets, axle stub shafts, u-joints) Would just need the spindles (just sold a pair a couple months ago, too. lol) brakes, hubs and calipers.
Also - A Dana 50 center section will bolt into a Dana 44 housing.
Dana 44:
1980-1996 1/2 Ton F150 & Bronco
Reverse rotation high pinion
Center section is steel
Ring Gear Diameter: 8.5"
Ring Gear Bolts: (10) 3/8" X 24RH
Cover Bolts: 10
Carrier Breaks: 3.73/3.92
Spline Count: 30
Pinion Support: False
Axle Lugs: 5x5.5
Dana 50:
* Ring gear measures 9.0".
* 30 Spline Axle shafts.
* Gear Ratios: 3.55:1 - 5.38:1
* No carrier breaks
* Pinion shaft diameter: 1.375"
* Pinion shaft splines: 26
* Axle shaft diameter: 1.21"
* Axle spline diameter: 1.31"
* Axle Lugs: 8x6.5
* Center section is steel
Rear Axle
Rear axle would most likely be a full float full width Dana 60,14 bolt or Sterling.
Optional: Build a shaved 14 bolt setup for links and an artec truss (Which would not be approiate for this project - $$$), that would eventually go into the black truck. Then move the rear Dana 60, currently going into the black truck, onto this vehicle. It'd already be set up for the Ranger leafs that way (plus already locked and disc'd). This option would restrict me to using a , or regearing the rear axle after a swap. .
I just need to learn how to weld. Haha.
:weld
Re: Plan B
Postby TexasArmadillo » Tue Oct 23, 2012 11:05 am
Welding is easy. You'll pick it up quickly.
Re: Plan B
Postby TxPlates » Tue Oct 23, 2012 2:00 pm
Fair enough.
Re: Plan B
Postby TexasArmadillo » Tue Oct 23, 2012 7:12 pm
It is just a short circuit between a positive and negative lead. All ur doing is just adding a filler in a nice pattern. I think I am going to go fix my welder so I can make a hat rack.
Re: Plan B
Postby KF5ZXT » Tue Jan 29, 2013 10:22 am
Re: Plan B
Postby Justin Klare » Tue Jan 29, 2013 11:38 pm
and you quoted all that why?
Re: Plan B
Postby KF5ZXT » Tue Jan 29, 2013 11:43 pm
To preserve information?
Re: Plan B
Postby Kris Guilbeaux » Wed Jan 30, 2013 10:48 am
I'm glad our Private conversations are now public. Thanks Randall.
Re: Plan B
Postby KF5ZXT » Wed Jan 30, 2013 10:50 am
:lol
Re: Plan B
Postby TxPlates » Wed Jan 30, 2013 11:05 am
It was pretty juicy.
Re: Plan B
Postby nice59fordf100 » Wed Jan 30, 2013 11:45 am
So is the plan still a 96 Explorer 5.0?
Re: Plan B
Postby KF5ZXT » Wed Jan 30, 2013 12:03 pm
I'm a little open at this point. A 5.0 Explorer or 4.0 OHV 4x4 short bed Ranger. We'll see what comes up around the beginning of March. It's at that point that I would need to decide to put this project on the power broil front burner in order to get something ready in time for Moab.
Re: Plan B
Postby nice59fordf100 » Wed Jan 30, 2013 12:30 pm
Well, if time is your concern, I would just start with a ranger that is already set up (motor, frame, cab, ect) for what you are wanting
