Demon4x4.com • View topic - 92 5.0 swap thread
92 5.0 swap thread
Re: 92 5.0 swap thread
Postby Kris Guilbeaux » Thu Jun 28, 2012 6:41 pm
Slacker!!!!
92 5.0 swap thread
Postby KF5ZXT » Thu Jun 28, 2012 6:43 pm
Hahaha.
Postby nice59fordf100 » Thu Jun 28, 2012 6:51 pm
im sorry i suck :(
Postby TxPlates » Thu Jun 28, 2012 8:28 pm
Oh my, where has this thread gone to?
Postby Kris Guilbeaux » Thu Jun 28, 2012 10:05 pm
Dark pics I am sorry...
Pan clearance.
driver side motor mount.
passenger mount.
trans tunnel
Postby TxPlates » Thu Jun 28, 2012 10:40 pm
I'm going to need you to get a better photographer.
Postby KF5ZXT » Thu Jun 28, 2012 10:42 pm
Wow, those are some dark photos. I like how you captured the drama of the... umm, what Chris said.
Postby Kris Guilbeaux » Fri Jun 29, 2012 7:10 am
Fine I will schedule a re-shoot.
Postby zavaral » Thu Jul 12, 2012 4:46 am
I can't wait for it to be finished. Its looking good from what I can see in the dark pictures.
Postby TxPlates » Thu Jul 12, 2012 4:38 pm
There have been no updated photo shots.
Postby Kris Guilbeaux » Wed Jul 18, 2012 11:23 am
Im sorry.. :cry
Postby Kris Guilbeaux » Sun Nov 25, 2012 6:10 pm
So the transmission hasn't played very nice with doing the 5.0 in a stock height 4wd explorer. I have the motor as low as it can go on the frame which gives me about a 1/4" to 1/2" on clearance till it hits the pivot bracket.
This has it about 1.5 Inches higher in the engine bay over a second gen. so the Exhaust was shooting straight in to the fire wall and I could not get the bell housing on the trans to squeeze into and tuck up to the body, it was hitting the floor pan. So I installed a one inch body lift to help with the clearances.
now I have room for the exhaust now too.
now I have to raise the front bumper and grill guard.
Postby KF5ZXT » Sun Nov 25, 2012 6:14 pm
Nice job sir. Nice to see some work getting done on some rigs in here.
Are you saying that you think it would work with either a body lift or a suspension lift, since the latter would drop that pivot point?
Postby TxPlates » Sun Nov 25, 2012 6:54 pm
When is the tranny going in, expected completion date for this rig?
Postby Kris Guilbeaux » Sun Nov 25, 2012 7:06 pm
Yes with a sas you could drop the motor down farther in the engine bay and no radius arm cross member to contend with
Postby Kris Guilbeaux » Tue Dec 04, 2012 12:20 am
So even with the one inch body lift I'm still having floor pan clearance on the driver side so tomorrow ill be beating the shit out of the floor pan.
Postby KF5ZXT » Tue Dec 04, 2012 12:23 am
Sounds like fun. That's what I had to do to get the atlas to fit, as you no doubt recall.
Postby Kris Guilbeaux » Tue Dec 04, 2012 12:27 am
No I try to forget the 700r4 swap I'd rather not remember it.
Postby KF5ZXT » Tue Dec 04, 2012 12:31 am
C'mon, it was fun.
Postby TxPlates » Wed Dec 05, 2012 3:46 pm
At this point, I'm guessing it was not. Some simple pounding and it's the floor, no one will see.
Postby Kris Guilbeaux » Thu Dec 06, 2012 12:01 am
The pounding I did today was just to the right of the gas pedal just FYI
Postby TxPlates » Thu Dec 06, 2012 12:10 am
Solve the problem?
Postby Kris Guilbeaux » Thu Dec 06, 2012 12:32 am
Not sure yet I was too tired to attempt the fitment tomorrow I can try
Postby KF5ZXT » Mon Jul 22, 2013 9:42 am
Is the plan still to use a 4.0L plastic radiator? Do you think that will offer enough cooling capacity for the larger motor?
Also, what about the fuel pump? I read somewhere that v6 fuel pumps don't have enough juice to properly feed a v8, which could cause destruction under WOT. :eek
Found this stock replacement 4.0L radiator made out of aluminum:
Postby KF5ZXT » Tue Aug 06, 2013 11:30 am
Updates after welder guy came by?
