So after months of head scratching looking at the motor in the engine bay and wondering why is this thing so flippin high in the engine bay. These aftermarket motor mounts put the motor up way higher then I wanted the motor. So, with the help of a welder buddy away I went cutting a notch in the oil pan and modifying the James Duff motor mounts to get this motor to play limbo in the engine bay. So how low can you go 5.0?
New oil pan clearance at the drop bracket
AC compressor clearance at the frame rail
Hey look the exit of the passenger exhaust has clearance now!!!
Looks like I will have AC too.
Room for the transmission to fit too
Steering has clearance too
The motor is sitting in the engine bay as low as I can get it now.
Thoughts? comments?
