Demon4x4.com • View topic - Rock Trac SAS
Rock Trac SAS
Rock Trac SAS
Postby KF5ZXT » Mon May 14, 2012 2:16 pm
Parker took too long to start it, so... :D
He's getting from mine:
79 Bronco narrowed HP Dana 44
- 4.88 gears
- Detroit SofLocker
- Custom TAG diff cover
- Mile Marker Manual Hubs
91 Explorer 8.8
- 4.88 gears
- Powertrax No-Slip
- Dutchman Alloy Axle Shafts (5 on 5.5 bolt pattern conversion)
- Mountain Offroad Anti-Wrap Spring Perches and shock mounts
79 Bronco Radius Arms and mounts
Energy C-Bushings (used 7 degree, new 5 and 3 degree)
Track bar and steering
Wild Horses 5.5" Early Bronco Rock Crawler coil springs
91 Explorer steering box
Drop Pitman Arm
4x Rancho RS9112's
Randall's D44 Trail Repair Kit (TM)
- spare hubs
- drive slugs
- all 4 ball joints
- U-joints
- Pinion Yoke
Additional stuff I think he'll need:
Parts:
: $129
: $46
Some kind of tack bar bracket:
: $25.99 OR
: $31.99
OR this combo unit:
Re: Rock Trac SAS
Postby TxPlates » Wed May 16, 2012 3:37 pm
Indeed, I'm slow :(
We're looking to get this swap going soon, so we can get wheeling!
Re: Rock Trac SAS
Postby Justin Klare » Fri May 18, 2012 12:03 pm
I'm going now :-P
Ok not really.
Re: Rock Trac SAS
Postby KF5ZXT » Fri May 18, 2012 12:16 pm
I'm seriously thinking about creating a backup vehicle in 2013 to limit down times to an effective zero. We need to be out in the dirt. :)
Re: Rock Trac SAS
Postby TxPlates » Fri May 18, 2012 12:18 pm
That gets the Parker stamp of approval.
Re: Rock Trac SAS
Postby Kris Guilbeaux » Mon May 21, 2012 8:20 am
Cool with me.
Re: Rock Trac SAS
Postby Kris Guilbeaux » Tue May 22, 2012 8:03 am
You know we can convert you to disk brakes on the rear axle after this swap is complete.
Re: Rock Trac SAS
Postby KF5ZXT » Tue May 22, 2012 8:40 am
Good plan.
Re: Rock Trac SAS
Postby TxPlates » Tue May 22, 2012 11:12 am
Let's do it.
Rock Trac SAS
Postby KF5ZXT » Fri Jul 06, 2012 5:46 pm
Coil buckets, shock towers and track bar bracket have arrived.
Re: Rock Trac SAS
Postby TxPlates » Fri Jul 06, 2012 6:00 pm
Oh sweet! Should we paint them before we take them to the shop?
Re: Rock Trac SAS
Postby Justin Klare » Fri Jul 06, 2012 6:01 pm
No. They need to be painted on the truck.
Re: Rock Trac SAS
Postby TxPlates » Fri Jul 06, 2012 6:02 pm
Oh, alrighty.
Re: Rock Trac SAS
Postby Justin Klare » Fri Jul 06, 2012 6:05 pm
They'd have to grind the paint off in order to get a good weld. So just paint them on the truck.
Re: Rock Trac SAS
Postby TxPlates » Fri Jul 06, 2012 6:06 pm
Are these parts being welded on?
Re: Rock Trac SAS
Postby KF5ZXT » Fri Jul 06, 2012 6:06 pm
Yes.
Re: Rock Trac SAS
Postby Justin Klare » Fri Jul 06, 2012 6:09 pm
^what he said.
Re: Rock Trac SAS
Postby TxPlates » Fri Jul 06, 2012 6:14 pm
I thought these were adjustable and to be welded later on in life?
Re: Rock Trac SAS
Postby KF5ZXT » Fri Jul 06, 2012 6:19 pm
The base of it gets welded on, then the adjustable portion adjusts off of that base.
Re: Rock Trac SAS
Postby Justin Klare » Fri Jul 06, 2012 6:19 pm
They'll still be adjustable when they're welded on. They're adjustable by the many holes in the sides. Bolts hold the bucket and backers together.
Re: Rock Trac SAS
Postby TxPlates » Fri Jul 06, 2012 9:16 pm
Ahhhh that was what Randall was saying. When we find the correct height have them weld it in place them as well in the correct hole , no?
Re: Rock Trac SAS
Postby KF5ZXT » Fri Jul 06, 2012 9:30 pm
That part is optional, but is what I would likely do. You could leave it adjustable.
Re: Rock Trac SAS
Postby Justin Klare » Fri Jul 06, 2012 10:20 pm
I'd leave it adjustable. Grade 8 bolts would be sufficient enough without welding everything together.
Re: Rock Trac SAS
Postby TxPlates » Fri Jul 06, 2012 11:33 pm
The infamous grade 8
Re: Rock Trac SAS
Postby TexasArmadillo » Sat Jul 07, 2012 5:23 pm
I found a grade 9 for a winch on two machines at work.
