Demon4x4.com • View topic - Project Upgrade the brakes 1992 Navajo
Postby Kris Guilbeaux » Tue Jul 02, 2013 3:12 pm
With not being satisfied with the braking on my 92 Mazda Navajo I will be making some changes. These changes include:
95-01 Explorer brake calipers front
95-01 Explorer pads
95-97 Ranger steering knuckles
95-01 Explorer brake booster and master cylinder
As I go along and install the set up ill take more pictures
Here is the cleaned knuckle with the new ball joints pressed in.
Re: Project Upgrade the brakes 1992 Navajo
Postby KF5ZXT » Tue Jul 02, 2013 3:34 pm
I just got a 95-01 master cylinder myself. Any differences between the booster between the 95-01 and the 91-94? Also, do those knuckles bolt up to the TTB 35, or do you have to modify anything?
Postby Kris Guilbeaux » Tue Jul 02, 2013 3:43 pm
I'm not sure there is much if any difference in the 95-01 booster except the amount of vacuum that is being pulled from the motor. These knuckles will attach to the Dana 35 with out modification
Postby TxPlates » Tue Jul 02, 2013 4:48 pm
Are you going to spray the knuckles black? Is the rear drum or disc? If drum going to upgrade to disc?
Postby Kris Guilbeaux » Tue Jul 02, 2013 5:16 pm
The Navajo already has a 98 explorer disc brake rear end. I will also paint the set up
Postby Kris Guilbeaux » Sat Jul 20, 2013 11:01 am
So I spent my birthday installing all of this on my Navajo.
When well with a few snags. First snag was the 95+ explorer booster won't bolt in so I'm using the 92 booster still. I used a 95-97 master cylinder it bolts right in and has the same low level connector.
Also when I was ready to install the rotors I found the 92 rotors had a different off-set. So this meant I had to purchase 95-97 ranger rotors.
I haven't bled the brakes yet so I can't give you a report yet on the improvement. But here are some pics of it all installed
And this is a before picture....
Postby KF5ZXT » Sat Jul 20, 2013 11:04 am
Nice. Those rotors look a bit bigger. Any side by side shots?
Postby Kris Guilbeaux » Sat Jul 20, 2013 5:25 pm
After driving it braking is much better a lot less brake fade and the master cylinder is powering the rear brakes like they are suppose to, and above all it stops on a dime.
Postby TxPlates » Sat Jul 20, 2013 5:52 pm
Stopping is always a bonus. Glad to see it worked out. Going to do this to any others?
Postby KF5ZXT » Sat Jul 20, 2013 8:04 pm
or do a tech write up? :)
