Demon4x4.com • View topic - Red Bull 2 Project starts
Page 1 of 5
PostPosted: Tue Mar 21, 2006 6:30 pm
today I picked up the front clip for my Newest Explorer. The Goal is to have a 95+ explorer looking truck with a v-8 with factory wiring with the 92 Frame and a solid axle. 4.88 gears and 37" tires.
PS. Jeff Since you wanna work on our Trucks sooo badly once the Body is done I will let you do the SAS swap on it. :D
PostPosted: Tue Mar 21, 2006 11:31 pm
Did the 95 not have TTB? Did they switch over to IFS that year?
PostPosted: Wed Mar 22, 2006 6:19 am
PostPosted: Wed Mar 22, 2006 8:56 am
PostPosted: Wed Mar 22, 2006 8:57 am
PostPosted: Wed Mar 22, 2006 9:22 pm
PostPosted: Wed Mar 22, 2006 11:17 pm
PostPosted: Thu Mar 23, 2006 12:11 am
PostPosted: Thu Mar 23, 2006 5:36 am
PostPosted: Thu Mar 23, 2006 8:43 am
PostPosted: Thu Mar 23, 2006 9:55 am
by Drunk Monkey
PostPosted: Thu Mar 23, 2006 10:23 am
PostPosted: Thu Mar 23, 2006 6:04 pm
PostPosted: Fri Mar 24, 2006 9:09 am
by Drunk Monkey
PostPosted: Sat Mar 25, 2006 8:54 am
PostPosted: Sat Mar 25, 2006 12:20 pm
PostPosted: Sun Mar 26, 2006 2:08 am
This 1992 Ford Explorer has been converted to Diesel by swapping in a 3.9 Liter Cummins Diesel. The engine came from a Frito-Lay step van.
This Explorer reused the stock P/S pump and A/C compressor and relocated the batteries to the back behind the tires on the kick panels. It is really a smooth set up. It's believed he even used the stock radiator. The diesel is a 4BT Cummins
The truck uses the stock motor mount on the drivers side..... but made a simple bracket to connect the block to the mounts. It uses a Chevy tranny, 700r4 and is 2wd. The stock t-case (which is what he will be using) was a 13-54 and will be fitted to the tranny by a custom adapter. It is electric shift, so no custom linkage, just spliced wires.
He did have to cut the crossmember under the motor, and make another since it did not allow for the oil pan. The main reason for the swap was because the diesel lasts so much longer, and there was some sort of a major problem with the motor in the 1st place, so he swapped it out.
The fan is now electric because the water pump that it would usually bolt to is in a totally different place and would not allow it to fit correctly.
He compensated for the weight by putting spacers under the springs.
Ask and you shall recieve :wink
PostPosted: Sun Mar 26, 2006 9:33 am
Fawk that is sweet.
PostPosted: Sun Mar 26, 2006 11:41 am
by Drunk Monkey
PostPosted: Sat Apr 08, 2006 7:25 pm
new pitures of Red Bull 2...
PostPosted: Sat Apr 15, 2006 3:45 pm
Why Is jeff the only one that is considered a Madman. LOL
Destruction is all part of creation.
PostPosted: Mon Apr 17, 2006 5:06 am
Wow, Im such a dumbass, for some reason I thought it was a two door :crazy
I dunno where I got that idea, but then again the original Red Bull was a four door, OK class I'll pay attention now!
GREAT JOB KRIS!
You definately have your work cut out for you, to be honest I'm not sure if even I would personally have bitten that project off or not, prolly might have, but then again.....................
Still kickass progress there sir!
Jeff - :skull
PostPosted: Thu May 18, 2006 11:56 am
by Stang Girl
I got to see Red Bull 2 in person yesterday....nanananana. :P
Anyway, Kris had done a lot of work, and a lot more to go, but this truck is going to be AWESOME when it's finished. :twisted:
PostPosted: Wed Jun 28, 2006 9:00 pm
Well I felt it would be easier to finish Red Bull 2 if I had a Good donor Truck for the drive train. So apon my search for a donor I run across this 96 Explorer v-8 2wd 89K... So I start a smiling. I get a hold of the owner we work out a deal and I should soon have my donor here in victoria.
PostPosted: Wed Jun 28, 2006 9:08 pm
Always finding those deals!
