Demon4x4.com • View topic - 91 Exploder Dana 60 Install
Postby KF5ZXT » Tue May 07, 2013 5:07 pm
Re: 91 Exploder Dana 60 Install
Postby KF5ZXT » Tue May 07, 2013 5:33 pm
Postby Kris Guilbeaux » Tue May 07, 2013 5:51 pm
No drive shaft in that last pic.
Postby KF5ZXT » Tue May 07, 2013 5:52 pm
It's in there, just not hooked up on the front yet.
Postby Kris Guilbeaux » Tue May 07, 2013 6:03 pm
How much longer till your loading it up
Postby KF5ZXT » Tue May 07, 2013 6:04 pm
Drive belt broke. Lol
Postby KF5ZXT » Tue May 07, 2013 6:08 pm
Master cylinder from a 2001 Dodge 2500 diesel with disc brakes. Bolts right in.
Postby TxPlates » Tue May 07, 2013 7:10 pm
Sweet, I assume we'll see an updated pic once on the trailer.
Postby KF5ZXT » Tue May 07, 2013 10:54 pm
Almost done... the front R&P was bad (in addition to not being the ratio that I thought it had - I bought it already set up with '5.13's' and a Detroit.) There was a little slop in the front when I was about to load it up on the trailer, so we pulled the cover. Motherfucking 4.88 gears. So if anyone has a HP D60 5.13 set lying around in the Houston area that I could come get in the early AM that I could buy off you, or I can order you a new set shipped to your door, whichever works best, I'd greatly appreciate it. Was trying to load up to head to Moab this evening. :FAIL
Postby TxPlates » Wed May 08, 2013 7:22 am
Any places Long the way that you can stop and pick one up and put in when you get there?
"And you are?"
Postby KF5ZXT » Wed May 08, 2013 7:25 am
Possibly
Postby TxPlates » Thu May 09, 2013 8:46 pm
Based on the pix in the Moab thread, looks awesome. Glad it worked out so far. Love that front stance, although you need a meaner looking front bumper :)
Postby KF5ZXT » Thu May 09, 2013 10:40 pm
It's just the low angle of the pic. The bumper is sweet, in my opinion. I want a rear one just like it.
Postby TxPlates » Fri May 10, 2013 10:32 am
Maybe just needs a fresh coat of paint :p Regardless love the stance. How's it holding up so far?
Postby KF5ZXT » Thu May 16, 2013 9:00 am
The SAS itself is holding up pretty well, other than a brake issue. My brakes are pretty much locked up. I need to go in and adjust the booster. Also, my new power steering pump pulley needs a spacer. It is currently about a rib too short and is shredding belts. The steering also has a bit of a hiccup in it that needs to be worked out.
Postby KF5ZXT » Thu May 23, 2013 8:42 am
Postby KF5ZXT » Thu May 23, 2013 8:46 am
Postby KF5ZXT » Thu May 23, 2013 9:02 am
Postby TxPlates » Thu May 23, 2013 9:54 pm
Definitely a sweet set up, although your rig could use a nice cleaning....lol EVEN if you're not rocking the MTR as a tire, I guess the ones you have will do for now...LOL. I know you're planning on taking it back to TAG for tweaking things, anything you can do on your own?
Postby KF5ZXT » Thu May 23, 2013 11:35 pm
Yeah, but the stuff I'll have them tweak is presumably covered under what they did. I've got a list of things I need to do to it, as well, once I get it back.
