Demon4x4.com • View topic - Cheap Lift for my Sport, and 4x4 conversion?
Re: Cheap Lift for my Sport
Postby KF5ZXT » Thu Oct 18, 2012 11:19 am
I would recommend a 10" wheel for a tire width of 12.50 or more, but less than that, I'd go with an 8" width. Of course, if you have plans of later getting a wider tire, then by all means get the wider wheel now, so you don't have to get new ones. Often, tire manufacturers will have recommended wheel width's for certain tires. BFGoodrich's recommended wheel width for their 31x10.50x15 is 7"-9".
Postby mr. everyman » Thu Oct 18, 2012 11:31 am
okay that makes sense
About as close to unreality, as never being, ever was.
mr. everyman
Cowboy Crust Buster & Rule Bender
Postby TxPlates » Thu Oct 18, 2012 4:35 pm
Nebulous, I also have some 16" spare rims with some rotten tires for sale as well.
Postby KF5ZXT » Thu Oct 18, 2012 4:35 pm
Lol.
Postby TxPlates » Thu Oct 18, 2012 4:39 pm
If you would like to see them, they're at Randalls. Please let me know asap, as there is a lot of buzz around this particular set and I'd hate for you to miss out.
Postby BigTim55 » Thu Oct 18, 2012 4:49 pm
Postby KF5ZXT » Thu Oct 18, 2012 5:26 pm
You got ripped off. Lol
Postby BigTim55 » Thu Oct 18, 2012 5:43 pm
Postby KF5ZXT » Thu Oct 18, 2012 5:50 pm
The ones at my house are 29's, at best.
Postby BigTim55 » Thu Oct 18, 2012 6:20 pm
Postby KF5ZXT » Thu Oct 18, 2012 6:21 pm
No.
Postby BigTim55 » Thu Oct 18, 2012 6:31 pm
Well damn nvm then lol
Postby TxPlates » Thu Oct 18, 2012 6:45 pm
Where's my $200 ???
Postby KF5ZXT » Thu Oct 18, 2012 6:50 pm
Sorry, I had to get beer.
Postby TxPlates » Thu Oct 18, 2012 8:47 pm
Fail.
Postby KF5ZXT » Thu May 16, 2013 10:23 am
Nebulous, we need your axle code off of your truck so we can start looking for which 4x4 conversion parts you'll need.
Ford Motor Company drive axle gear ratio and transmission gear ratio codes may found on the Vehicle Certification label or the Vehicle Rating Label. The Certification label is typically attached to the door latch edge on the driver side door.
This label is from a 1999 Ford Explorer, the axle code is "42", and the transmission code is "D".
Re: Cheap Lift for my Sport, and 4x4 conversion?
Postby mr. everyman » Fri May 17, 2013 1:21 pm
It's a 46 J
mr. everyman
Postby KF5ZXT » Fri May 17, 2013 1:30 pm
Ok, you've currently got 3.73 gears, open differential, and an M5OD-R4 Transmission. Basically, whever donor vehicle you get the 4x4 trans from needs to be a J from 2002-2003, and the Axle code needs to be a 46 (3.73 open) or D4 (3.73 Limited Slip) axle, unless you plan to re-gear. Also you will need driveshafts from a 4x4 Sport, and of course a transfer case (preferably manual shift).
Postby TexasArmadillo » Fri May 17, 2013 4:03 pm
What are the benefits of manual over electronic transfer cases?
Postby KF5ZXT » Fri May 17, 2013 4:04 pm
Reliability (manual) vs. ease of use (electronic).
Postby TxPlates » Fri May 17, 2013 5:17 pm
Postby KF5ZXT » Fri May 17, 2013 5:20 pm
I can understand that, but I think it's a small price to pay for reliability.
Postby TxPlates » Fri May 17, 2013 6:31 pm
You enjoying the heat through the floor?
"And you are?"
Postby KF5ZXT » Fri May 17, 2013 6:37 pm
The heat from the hole from my tcase shifters is not noticeable.
Postby TxPlates » Fri May 17, 2013 7:48 pm
Even so, it's a lot of space it takes up by the drivers foot space. I enjoy my space, and the clean look. Aesthetics for the win!
