Demon4x4.com • View topic - Hacked Gadgets
Hacked Gadgets
Hacked Gadgets
Postby SVO » Sun Sep 02, 2007 12:13 am
SPECS:
* Chevy 3/4 ton frame… shortened 12 inches
* 1995 Chevy 305 V8 … Edelbrock 4 barrel intake, quadrajet carb
* Turbo 350 trans…. internals new.. clutches, bearings,… mild shift kit
* 231 Transfer Case… full time 4wd with lockout hubs
* Dana heavy duty 3/4 axles
* Cooling system…. Oversized radiator from dodge V10 truck
* Rancho 4 inch reached springs in front… blocks in rear
* Block hugger headers
* custom brush guard, nerf bars, tube bumper
Interior is original with exception of doghouse for larger engine. Complete set of new Equis white phantom gauges, Alpine cd player.
This Van is a work in progress… I did drive it to work daily, but I had to switch engines after the first engine had a bad cylinder. The current engine was amazingly clean inside and out, should have several years left on it. Transmission has new internals, but unfortunately when I put in the new engine I cracked the bell housing… it can be welded up by anyone who has access to a tig welder, and due to high clearence it can be done with trans still in van. Just needs alot of TLC and I have to many projects so I need to free up a little room at my house!!”
