Demon4x4.com • View topic - Fuel Cap Fix
Fuel Cap Fix
Fuel Cap Fix
Postby TexasArmadillo » Wed Jul 24, 2013 9:31 am
Here is the quote I received from Grapevine Ford on the part's cost to fix my capless fuel inlet. I think I will remove the neck this week to see if there is not some way I can fix the inlet without buying a whole new setup.
Re: Fuel Cap Fix
Postby KF5ZXT » Wed Jul 24, 2013 9:34 am
Which vehicle is this on? Are you saying that the inlet hose is currently unable to accept the cap?
Re: Fuel Cap Fix
Postby TexasArmadillo » Wed Jul 24, 2013 9:44 am
This is for the 2010 Explorer. It is a capless system. There is a little flap on the inside that keeps a vacuum for the EVAP. That flap has failed and has left me with a CEL for 2 months now. I've been lazy with fixing it, but the other day the flap moved in a way that would not allow me to add gas. I finally got it to work, but only after pushing it back in.
Re: Fuel Cap Fix
Postby KF5ZXT » Wed Jul 24, 2013 9:47 am
Must be just out of warranty, then?
Re: Fuel Cap Fix
Postby TexasArmadillo » Wed Jul 24, 2013 9:50 am
Ya it is. I also have a electrical problem in the front end of the vehicle. That is a low priority though since it only effects the cabin lights.
Re: Fuel Cap Fix
Postby TxPlates » Wed Jul 24, 2013 10:28 am
I feel your pain, both of my Fords have electrical issues.
Re: Fuel Cap Fix
Postby KF5ZXT » Wed Jul 24, 2013 10:42 am
Try owning a BMW.
Re: Fuel Cap Fix
Postby TexasArmadillo » Wed Jul 24, 2013 10:09 pm
Negative. No BMWs. I've heard way to many horror stories.
Re: Fuel Cap Fix
Postby TxPlates » Wed Jul 24, 2013 10:23 pm
Try owning an Audi, and not loving it.
Re: Fuel Cap Fix
Postby KF5ZXT » Wed Jul 24, 2013 10:27 pm
Are you having electrical issues?
Sent from my iPhone using Tapatalk 2
Re: Fuel Cap Fix
Postby TexasArmadillo » Sat Aug 03, 2013 12:25 am
So after buying the part I pulled the part I needed from the whole neck harness. I figured it would be easier then dropping the tank to install the whole dang thing. I transplanted the part I needed to. Unfortunately, I made a trip down to Lampasas and I got another CEL. This time it is a small EVAP leak. I'm not 100% sure where it is. Hopefully, i do not have to change the whole neck out.
Users browsing this forum: No registered users and 16 guests
