Mechanical Mock-Up Phase 99% Complete!
I pulled the motor and transmission again today.
So as far as the mock-up goes, it's pretty much a done deal, a little trimming on the powersteering pump to give a little more clearance to the high pressure and return hose.
Clearence the valve cover breather seperator on top of the valve cover to firewall.
Still had to modify the motor mounts to get the right dangle on the angle.
May still have to get a Ranger automatic transmission filler tube and dip stick.
BUT! I can now start on getting the wiring set-up, so now I need to pull the dash assy and start building the wiring harnesses that will be used for the chassis and powertrain.
These motor set-ups are already a cluster from Ford (wiring and plumbing), so I'm going to try and clean it up as much as possible to that majority of the wiring is hidden.
Here are some pictures, that should give you and idea of
FINALLY how it's all supposed to fit in there, note how far back it sits and the, and there is no more list to the driver's side, very close tollerances between the engine and firewall, plus the power steering pump bracket/steering gear box, and that it all fits under the hood line nice and clean.
Feels like I finally got somewhere today!
Enjoy!
:D:D
