Demon4x4.com • View topic - Gear installs...
Gear installs...
Gear installs...
Postby Sexy Evil ST » Tue Jan 27, 2004 12:06 am
Ok, I thought I had a deal in Dallas to do an axle swap and give the guy some cash for an axle with 4.10 gears.<br><br>He miss understood what I wanted. He thought I was buying the axle from him for $550 and paying him time and use of his garage for $100 to swap the new axle underneath my truck and me keeping my 3.73 axle.<br><br>So, I need help determining the price break point of buying an axle with 4.10's or buying the 4.10 gears and getting them installed.<br><br>So my question is, how much would it cost to get 4.10 gears installed in my current rear differential. I'm not worried about the front diffy yet, I'll run with the front driveshaft off until I can afford the install in the front. BTW, I'm already buying the front gears from Gerald.<br>I already know that a Master install kit would probably cost around $100. But, do I need one, since my 3.73 rear end only has 36K miles on it?<br><br>The other week in El Paso, I found a junkyard with an 8.8 and 4.10s and the guy said he wanted $450 for it.<br>I will also check the junkyard here in Houston that I frequent for a 4.10 axle. I saw one there once. I need to go there to look for a wheel bearing/hub assembly for the Sport Trac anyway.<br><br>Thanks for the help.<br>Regards,<br>John <p></p><i></i>
It's hard out here for a chimp!
Sexy Evil ST
Re: Gear installs...
Postby Kris Guilbeaux » Tue Jan 27, 2004 1:30 pm
You will need a New master install kit. I tryed to get by once trying not to but I ended up having to buy one any way. <br><br>You need the Gears and master kit. And depending on person that does the work charges for the Labor<br><br>Kris <p></p><i></i>
Postby Sexy Evil ST » Tue Jan 27, 2004 4:50 pm
But, what's a ballpark figure for labor?<br>Does anyone know a good gear person? <p></p><i></i>
Sexy Evil ST
Postby KF5ZXT » Tue Jan 27, 2004 10:29 pm
Texas Auto Gear will do it for $200-250. They do good work. <p></p><i></i>
Postby Kris Guilbeaux » Wed Jan 28, 2004 1:06 am
The Lowest I have seen is $150.00 and that was dirt cheap.<br><br> <p></p><i></i>
Users browsing this forum: No registered users and 6 guests
