Demon4x4.com • View topic - 92 5.0 swap thread
92 5.0 swap thread
92 5.0 swap thread
Postby Kris Guilbeaux » Tue Jun 05, 2012 9:40 am
Recently started the 5.0 swap on my 1992 Ford Explorer Jurassic Edition, after the rebuilt manual transmission failed after a bad syncro locked it in fourth gear.
This swap will retain the existing firewall and dash. The engine bay harness will be removed and will use a custom built 97/92 Engine bay harness. All second gen locations for the air box, battery, overflow, and cruise control will be used. AC and emissions will be retained on this Explorer. Also the Factory column shifter will be used.
The 5.0 is coming from a 97 Explorer and the trans will be a 4r70w from a 97 AWD explorer. The only thing I will use different is a 92 Ford bronco 1356 transfer case elec shift.
The 97 5.0 I picked up for a song and dance.
Home on the Engine Stand.
Removed the drive train
Then you have to make it clean for that new motor.
we then moved the battery tray and airbox to the new spots for test fit.
At this point we are at a slight stand still till Russell starts the wiring harness and he has mapped the harness out.
I also need to purchase my motor mounts so I can test fit the motor in the engine bay.
Re: 92 5.0 swap thread
Postby KF5ZXT » Tue Jun 05, 2012 9:58 am
I could have sworn you told me that about the PATS...
Postby Kris Guilbeaux » Tue Jun 05, 2012 10:44 am
Nope 98+ is pats
Postby Kris Guilbeaux » Sat Jun 09, 2012 7:51 am
motor mounts will be here Monday.
92 5.0 swap thread
Postby KF5ZXT » Sat Jun 09, 2012 8:05 am
Sweet
Are you still a James Duff rep? ;)
Postby Justin Klare » Sat Jun 09, 2012 10:21 am
What song and dance did you have to do to get that motor kris?
Postby TxPlates » Sat Jun 09, 2012 7:27 pm
C'mon, we all know Kris has magical powers.
Postby KF5ZXT » Sat Jun 09, 2012 11:07 pm
Good point.
Postby Kris Guilbeaux » Sun Jun 10, 2012 4:05 pm
I dunno about magical powers... No I do not get a duff discount any more thou I wish I did.
Also I only paid $175 for that 5.0 thats what I call a song and dance
Postby KF5ZXT » Sun Jun 10, 2012 5:28 pm
Um, yeah... Let me know if you see another one. :D
Postby TxPlates » Mon Jun 11, 2012 6:51 pm
I also still need a new throttle body.....
Postby Kris Guilbeaux » Wed Jun 13, 2012 9:33 am
Ill put that on my list when I go to Wrench a part next. Just FYI throw the Directions to the James Duff mounts in the Trash the mounts are beautiful but the Directions are garbage.
Postby KF5ZXT » Wed Jun 13, 2012 9:54 am
Good to know. You should write them some new ones and see if you can get your rep status back. :D
Do they come with grade 8 hardware? Hard to tell from the site's images.
Postby Kris Guilbeaux » Thu Jun 14, 2012 8:05 am
Added some clearance to the firewall
Russell adding the Transducer
Added the second gen evap system
New Frame harness
5.0 in but oil pan is keeping it from being dropping down all the way.
Postby KF5ZXT » Thu Jun 14, 2012 9:31 am
Is the firewall clearance for the 4R70W?
are you going to have to go with a dual sump oil pan?
Postby Kris Guilbeaux » Thu Jun 14, 2012 10:29 am
Yes I will be ordering the dual sump pan and the firewall clearance is because the motor sits higher then stock so you need clearance for the trans
Postby zavaral » Fri Jun 15, 2012 2:53 am
You didn't happen to keep the part numbers from everything you ordered. That would be awesome if you did, I was prolly gonna order the v8 conversion kit from james duff.
Postby Kris Guilbeaux » Fri Jun 15, 2012 10:25 am
Yeah I remember what I ordered. the Duff motor mounts are only thing I ordered so far. Its on their New Stuff page.
Postby zavaral » Sat Jun 16, 2012 12:19 pm
That's all you ordered and it just drops in!!!! I figured there would be more than that.
Postby KF5ZXT » Mon Jun 18, 2012 10:48 am
Which radiator are you going with?
Postby Justin Klare » Tue Jun 19, 2012 12:48 pm
The kind that coolant runs through to keep the motor cool :-P
Postby KF5ZXT » Tue Jun 19, 2012 1:04 pm
I didn't ask what kind. :finger
Postby TxPlates » Tue Jun 19, 2012 2:06 pm
Fail.
Postby Justin Klare » Tue Jun 19, 2012 5:35 pm
:( meanie.
Postby TxPlates » Tue Jun 19, 2012 10:08 pm
Klare you should be used to that from him by now.
Users browsing this forum: No registered users and 3 guests
