Demon4x4.com • View topic - 91 Exploder Dana 60 Install
Postby TxPlates » Tue Jul 10, 2012 5:58 pm
Oh shit, you truck is getting a pimp cane????
Postby TexasArmadillo » Tue Jul 10, 2012 9:21 pm
Gitty
Postby TxPlates » Tue Jul 10, 2012 9:24 pm
Mike, does yours have a pimp cane?
Postby TexasArmadillo » Tue Jul 10, 2012 10:40 pm
Mine has sync.
Postby KF5ZXT » Wed Jul 11, 2012 10:00 am
Ordered some . I think that is the last thing I need to buy... other than new rotors.
Other than that, just waiting on some other things that I had ordered to arrive.
Spindle studs - still
Lug studs, bearings
XLocks
Grease
Drill bit
Bling
Also, I've decided to attempt to drill out the rectangular hole on the H1 wheels to accept a fat valve stem. I measured the long end of the rectangular hole at .5051 with digital calipers, so I'm going to attempt to drill it out with a 1/2 drill bit. I'll probably try to set up some sort of jig on a drill press.
Postby TxPlates » Wed Jul 11, 2012 4:42 pm
Seems dangerous, and if you drill it to big?
Postby KF5ZXT » Wed Jul 11, 2012 4:51 pm
Then it'll have to be welded shut and re-drilled, or new outer shells purchased.
Postby TxPlates » Wed Jul 11, 2012 6:17 pm
Try not to drill to big then I suppose.
Postby KF5ZXT » Thu Jul 12, 2012 6:00 pm
Got in some other goodies that no one is likely to see once I get it all together.
Stage 8 X locks
Reid Racing spindle studs & bronze kingpin bushing
Longfield spindle bushings
Extreme axles spindle oil slingers
9/16-18 lug studs
And last but not least, a tasty beverage.
Postby TxPlates » Thu Jul 12, 2012 6:10 pm
One of your titled added should be "Parts Whore" :)
Postby Justin Klare » Thu Jul 12, 2012 7:52 pm
You forgot the Guinness.
Postby TexasArmadillo » Thu Jul 12, 2012 7:52 pm
So what is the major difference between the stage 7 and 8 X lockers?
Postby KF5ZXT » Thu Jul 12, 2012 11:09 pm
12.5%!
Justin: I said a tasty beverage!
Postby Justin Klare » Fri Jul 13, 2012 2:09 am
My bad. Must've missed that.
Postby TexasArmadillo » Fri Jul 13, 2012 7:22 am
Wow that is significant.
Postby KF5ZXT » Mon Jul 16, 2012 12:46 pm
Seriously though, Stage 8 is the name of the company that manufactures the X-Locks.
Postby KF5ZXT » Mon Jul 16, 2012 8:37 pm
In case anyone wanted to see the difference between Dana 60 and Dana 44 shafts (also old knuckle next to a new one):
Postby TxPlates » Mon Jul 16, 2012 9:03 pm
That's pretty stout. I love that orange on the knuckle.
Postby TexasArmadillo » Mon Jul 16, 2012 10:38 pm
Also significant.
Postby Justin Klare » Mon Jul 16, 2012 11:44 pm
Damn.
Postby TxPlates » Tue Jul 17, 2012 6:37 pm
Is you're rig going to be able to turn those big mofo's with only 3 cylinders?
Postby KF5ZXT » Tue Jul 17, 2012 6:44 pm
LMAO
Postby KF5ZXT » Tue Jul 24, 2012 2:23 pm
Well, apparently no one on Houston carries rotors for a 79 F350 4x4, so I ended up having to order them online anyway.
I drilled out the hubs for the new stud, went much easier than I thought it would. Hopefully drilling out the hummer wheels for the valve stem goes just as smoothly. I've currently got the bearing races for the lower king pins in the freezer. Hopefully they will contract enough that they will actually fit into the knuckle. I couldn't get them to go last night with a hammer and race driver.
Postby KF5ZXT » Tue Jul 24, 2012 8:56 pm
Got the driver's side knuckle and steering arm installed, then went to grease it up, and the upper kingpin seal is leaking. Now I get to take it all back apart. Yay!
Postby KF5ZXT » Wed Jul 25, 2012 7:42 pm
Driver's side knuckle reinstalled after breaking it all down to replace the upper kingpin seal. Also installed the 9/16-18 studs in the hub and rotor. Now I apparently need a bearing puller to get the old inner spindle bearing out of there so I can get it all together.
