Demon4x4.com • View topic - Question Time
Question Time
Question Time
Postby TexasArmadillo » Thu Sep 27, 2012 9:50 am
The above link is from the Serious Explorations board. What I am trying to figure out is what is a "Strong Box". At first I thought it was a slang word for a transfer case. However, as I look at it more I'm thinking it might be a transfer case mod. Do yall know what this is and what it does?
Sorry if this is a total noob question.
Re: Question Time
Postby KF5ZXT » Thu Sep 27, 2012 9:55 am
A strong box is essentially a doubler unit, goes in between the transfer case and transmission to add in an additional low (sometimes rarely a high) gear to increase crawl ratio (or overdrive). In it's general use, it allows you to 'go into low range twice' effectively compunding your low range gears. For example, the Borg Warner 1354/1356 transfer cases that come stock in early Explorers had a 2.48 low range. The Strong Box has a 2.48 low range. When both are engaged, you have a 6.15 low range.
Re: Question Time
Postby KF5ZXT » Thu Sep 27, 2012 10:02 am
Also, make sure you do some research on this particular doubler:
This is the underdrive unit that is on my wish list:
Re: Question Time
Postby TexasArmadillo » Thu Sep 27, 2012 10:36 am
Thank you Professor. I had a feeling it had something to do with a post transfer case application. I like one on ur wish list. Also, there marketing page was well built. That other one looks scary. I wonder how many failures it has lead to in the field. Thanks again for the info. I am still trying to build my knowledge on more advance off road modifications.
Re: Question Time
Postby KF5ZXT » Thu Sep 27, 2012 10:38 am
Feel free to keep on asking. If someone on here doesn't already know the answers, I don't mind doing research and learning a little something myself. Unless there are wires involved, then you'll need to find someone else. Hahah.
Re: Question Time
Postby Justin Klare » Thu Sep 27, 2012 2:06 pm
I have a doubler in my explorer.
Re: Question Time
Postby KF5ZXT » Thu Sep 27, 2012 4:52 pm
:cookie
Re: Question Time
Postby Justin Klare » Thu Sep 27, 2012 6:19 pm
And that is why I lack participation.
Re: Question Time
Postby KF5ZXT » Thu Sep 27, 2012 6:47 pm
That comment was not participating, it was making a random ass comment that had zero value.
