Demon4x4.com • View topic - Dana 44 Knuckle Swap on a D35 TTB
Postby KF5ZXT » Wed Oct 10, 2012 1:41 pm
Re: Dana 44 Knuckle Swap on a D35 TTB
Postby Justin Klare » Sun Oct 14, 2012 1:45 am
I could never keep my truck aligned.
Postby Kris Guilbeaux » Sun Oct 14, 2012 9:12 pm
The swap is good for trail rigs only and what they did on pirate was different then what I did
Postby KF5ZXT » Sun Oct 14, 2012 10:25 pm
I know it was different, it just reminded me of yours, so I came on here looking for the info.
Justin, had you done the knuckle swap on a 35?
Postby Kris Guilbeaux » Mon Oct 15, 2012 7:37 am
I gave him my swap after removing it from the Navajo
Postby KF5ZXT » Mon Oct 15, 2012 10:12 am
If I understand correctly, you used a spacer/sleeve in the D44 knuckle to use the D35 ball joints, rather than reaming out the D35 beams to accept a D44 ball joint. Is this correct? Do you think it would have worked better to do it that way (D44 ball joints)?
Postby Kris Guilbeaux » Mon Oct 15, 2012 11:28 am
No the 44 ball joints would have not worked the post were not made the same from what I remember
Postby KF5ZXT » Mon Oct 15, 2012 11:30 am
Hence why you would ream out the D35 beam to use them.
Postby KF5ZXT » Mon Oct 15, 2012 11:55 am
I found someone who did what I am talking about:
I know you have enough spare D35's laying around to try this. :lol
Postby Kris Guilbeaux » Tue Oct 16, 2012 10:32 am
Great info Randall.. Thanks for sharing. I might look in to some of these options when I start working on Russell's Navajo. Im sure I will be doing the build up on that one any way.
Postby TxPlates » Tue Oct 16, 2012 4:39 pm
I thought he was getting rid of the Navajo?
