Demon4x4.com • View topic - Dan's Dark Thunder - 1998 Dodge Ram 1500
Re: Dan's Dark Thunder - 1998 Dodge Ram 1500
Postby TxPlates » Wed Jan 09, 2013 7:59 pm
I'll say it. Mainly cause dodge blows ass. :p but nice that you made it safely to kris'.
Postby MrQ » Tue Oct 15, 2013 11:42 am
After a year of being driven by my dad, (who couldn't even do basic maintenance) I am now driving the Dodge. I almost forgot How much power this truck has. I can peel out on just half throttle. :finger
Anyways, I finally changed out the year and half oil and filter, redid the spark plugs and wires, and fixed the vacuum leak on the blend door. I also went ahead and threw on a set of 33's, need to recalibrate my speedo however. I also picked up a replacement fender for the passenger side which is still sporting damage from a side swipe 3 years ago. Need to paint it, unless I can find somebody to do it professionally. I am also going to put in a JVC DVD nav unit and an alarm. A rear locker is also in the works if I can find a good deal. On top of that I picked up the parts to fix the A/C as well, but I am going to have a shop professionally vacuum and fill the system.
In other words the truck is getting a complete overhaul that it has desperately needed. With the Explorer in the doghouse, I moved to the Dodge as a daily and, man, that SOHC is damn anemic in comparison with the 5.2. However, with nothing in the bed this truck has no traction in rain, period. In the last storm we had I just sat spinning my wheels trying to turn out onto the highway. Therefor the locker moved up in priority on my list. :8)
Postby KF5ZXT » Tue Oct 15, 2013 8:27 pm
Nice. Since you said the frames are different, prohibiting you from doing a traditional 4x4 swap, how about a non-traditional, i.e. weld some shit on, SAS style, and make this your offroad rig. We need a full size in the group. :D
Dark Thunder
Postby MrQ » Tue Oct 29, 2013 2:05 pm
i am hoping I can procur a locker for the ram. a 4wd conversion is now in the works for the green beast. :-D
Dark Thunder
Postby KF5ZXT » Sun Nov 10, 2013 5:07 pm
Nice. I thought you told me that was not feasible due to frame differences? What all is the plan?
Re: Hidden Falls, November 30, 2013
Postby MrQ » Mon Nov 11, 2013 2:18 am
To answer your question Randall, I am going to be doing a complete frame swap. I will essentially be building the truck from the ground up...again.
Postby KF5ZXT » Mon Nov 11, 2013 8:25 am
Postby MrQ » Mon Nov 11, 2013 1:54 pm
Yeah, I am going to pull all the parts together and then hopedully put it all together with some help in a weekend.
Postby KF5ZXT » Tue Nov 12, 2013 11:25 am
Out of curiosity, have you weighed that option vs. a custom front suspension and bracketry welded onto the 2wd frame? Seems like it would be easier and maybe even cheaper to me.
Postby MrQ » Tue Nov 12, 2013 11:36 am
Actually, its cheaper and will make replacement parts easier to find as well as proper modifications. i would love to make a custom setup. but lacking a proper welder and the knowhow it would probably turn into a huge mess.
Postby KF5ZXT » Tue Nov 12, 2013 12:05 pm
Oh, it seems something is missing from this thread:
:pics
I mean of the Dodge, not the group that it was named after.
Postby KF5ZXT » Wed Nov 13, 2013 12:13 pm
Only ones I could find:
Postby MrQ » Wed Nov 13, 2013 5:01 pm
i have some new onez Ill be uploading tonight with the my DvD Nav unit installed.
Postby KF5ZXT » Thu Nov 14, 2013 5:46 pm
So what kind of timeline do you think you're on for the 4x4 conversion/frame swap?
Postby MrQ » Thu Nov 14, 2013 7:42 pm
That's a tough call right now. The time frame is really going to come down to finding the parts at a decent price and having funding to purchase said parts. I don't see a due date on this project till the middle of next year. Of course that is always subject to change if I get a windfall of parts and/or monies. A lot of of the funding will be coming from next years tax return.
Postby TxPlates » Thu Nov 14, 2013 10:08 pm
So are you scraping the explorer to do this?
Postby MrQ » Mon Dec 02, 2013 6:13 pm
That is a possibility. The only way I would keep the explorer is if I put a V8 in it, I am tired of that SOHC, its never run right and always had a bit of a rough idle till lately.
Postby AgPete139 » Wed Dec 04, 2013 11:41 am
Why the rough idle? Have you looked into what's causing it?
AgPete139
Postby MrQ » Wed Dec 04, 2013 2:14 pm
Multiple times. New air filter, replaced all intake gaskets, iac, maf, fuel filter. Nada.
Last bet was sparkplugs, coil pack or wires, but since the transponder in the key got wiped by pats when I tried to start it it is a moot point..
Postby MrQ » Thu Dec 05, 2013 9:20 am
Got a possible full size project vehicle in the works (other than Thunder)... crossing fingers.
Postby Kris Guilbeaux » Thu Dec 05, 2013 4:46 pm
Your keys got erased again?
Postby MrQ » Thu Dec 05, 2013 5:19 pm
Yup, I wonder if the computer is the one at fault here. It really shouldn't have done that just trying to start it...right?
Postby nice59fordf100 » Thu Dec 05, 2013 7:54 pm
Well there is always a way to check this..we might have another pcm to put in it and try - cause remember when red wiped the pats key back in moab?
Postby KF5ZXT » Thu Dec 05, 2013 7:56 pm
I'm sure he does remember...
Postby MrQ » Fri Dec 06, 2013 8:29 am
Users browsing this forum: No registered users and 29 guests
