The camera inside "the frame". Fits really nice and allows the USB charger slot to be open so you can charge while using it. Will be nice when I have it just on the dash. "The Frame" also comes with a rubber lens cover, nice thinking since it won't be protected when being moved around when not recording and not stationary.
I went to set it all up, but requires the micro sd card be in there to complete the update and set up the wifi. Once it's here looks pretty easy as you just download the update, couple clicks and it updates the firmware. Then you name the camera and set up a password for the wifi.
You can download 2 different gopro apps. One is free and one is $1.99. It's going to allow access to the camera for all its setting and does provide a view onto your phone of what the camera is seeing. You can use the phone to remotely tell it to start, stop etc. or use the remote if you buy the full set up like I did. In order to use the wifi from the phone to the camera, you'll need to go into settings, wifi and click on the connection that lists the gopro and put in the password you made during the setup while updating the firmware.
And that's all I know for now.
Sent from you guessed it.
