by KF5ZXT » Mon Apr 08, 2013 10:45 am
That, and the minor detail of the solid axle swap part. Start looking around for JK axles, you'll need both front and rear. You'll need new wheels for the new bolt pattern (5 on 4.5), so don't go buying any before then. What travel are your current coilovers? You'll probably need new ones, along with shock hoops, unless you go a more traditional coil shock route, which is a little cheaper.
Does that truck have an actual build thread somewhere, or just this for sale thread?
