So I spent my birthday installing all of this on my Navajo.
When well with a few snags. First snag was the 95+ explorer booster won't bolt in so I'm using the 92 booster still. I used a 95-97 master cylinder it bolts right in and has the same low level connector.
Also when I was ready to install the rotors I found the 92 rotors had a different off-set. So this meant I had to purchase 95-97 ranger rotors.
I haven't bled the brakes yet so I can't give you a report yet on the improvement. But here are some pics of it all installed
And this is a before picture....
