Demon4x4.com • View topic - EEE's 1991 Ford Explorer
Re: Brake Upgrade, 91 Exploder
Postby KF5ZXT » Wed Aug 28, 2013 3:51 pm
Taking the truck in tomorrow AM to get it's inspection. I'm towing it up there so as to have have much time for the brakes to lock up. They'll not be driving it too far at the shop, so it should be good before the brakes lock up. Wish me luck. :lol
As an aside, I've now got a theory that there might be a vacuum issue with the motor, which would be causing the vacuum booster to lock up the brakes once the motors been running for a while. Thoughts?
Postby TexasArmadillo » Wed Aug 28, 2013 11:04 pm
Wouldn't surprise me. My sis had a 93 that had a vaccume problem that put oil in her transmission fluid.
Juggling more fur balls than a constipated cat.
Postby TxPlates » Thu Aug 29, 2013 6:52 am
Good luck this morning.
Postby KF5ZXT » Thu Aug 29, 2013 7:00 am
Thank you sir. Waiting for them to open now.
Postby KF5ZXT » Thu Aug 29, 2013 7:43 am
Fail. (Not the truck, the shop) I called yesterday to make sure that someone that could inspect was there at 7. I got there thirty minutes early to unload the trailer and whatnot c He was of course 25 minutes late. Then it turns out the mofo can't do anything but OBD.
Postby TxPlates » Thu Aug 29, 2013 8:59 am
Now what?
Postby KF5ZXT » Thu Aug 29, 2013 9:00 am
Gotta take it to a place with a dyno.
Postby TxPlates » Sat Aug 31, 2013 10:20 am
Know of a place around there that can do it?
Postby KF5ZXT » Sat Aug 31, 2013 5:08 pm
Yes.
Postby TexasArmadillo » Sat Aug 31, 2013 8:16 pm
I use to use a place off if Mason. They inspected my high school Oldsmobile that had a crazy knock. The guy was scared it was going to throw a rod. It did not.
Postby KF5ZXT » Sat Aug 31, 2013 8:48 pm
Well, throwing a rod is not on the list of things to check. Lol
Postby TexasArmadillo » Sat Aug 31, 2013 11:01 pm
They cannot fail you for that so I was good to go.
Postby KF5ZXT » Sat Sep 07, 2013 9:29 am
Ugh. Truck failed due to not being able to shift into second gear while on the dyno to finish the emissions test. Passed everything else.
Postby BigTim55 » Sat Sep 07, 2013 10:00 am
Postby KF5ZXT » Sat Sep 07, 2013 1:03 pm
EAT IT PAUL MCCEEVER!
Tranny needed more fluid. Has a small leak, which obviously needs to be addressed, but afterwards shifted just fine. Took it to the place and PASSED INSPECTION!
Postby TxPlates » Sat Sep 07, 2013 6:14 pm
Sweet, that rocks. Do you know where the leak is? Gonna be a pita to fix?
Postby KF5ZXT » Sat Sep 07, 2013 8:12 pm
I'll check it out in the AM.
Postby TxPlates » Sun Sep 08, 2013 9:45 am
I'm impressed your gas cap passed. Mine never seems to pass, every year the tell me it's bad. Every year I give them the finger lol. Thankfully we don't have emissions out here.
Postby KF5ZXT » Sun Sep 08, 2013 9:46 am
I've never had one fail. Odd.
Postby TxPlates » Sun Sep 08, 2013 9:50 am
That is strange, they always failed the other sport trac I had as well.
Postby BigTim55 » Sun Sep 08, 2013 2:17 pm
Failed for gas cap?
Sent from Xavier School for Gifted Youngsters
Postby TxPlates » Sun Sep 08, 2013 2:35 pm
Yes sir.
Postby TexasArmadillo » Sun Sep 08, 2013 8:37 pm
EVAP testing will get ya.
Postby KF5ZXT » Tue Sep 10, 2013 3:24 pm
Went shopping at for some fittings and whatnot that I need to complete the hydroboost. Quickly added up to over a hundred dollars. Might have to wait for Friday...
Product Name Unit Price Qty Subtotal
PSC Motorsports Field Serviceable #6 Universal Pressure Hose Kit - PSC-HK2034 SKU #: PSC-HK2034 $36.25 2 $72.50
Fragola 200106-CL #6 PUSH LOCK ENDSTR CLEAR SKU #: FRA-200106-CL $3.83 1 $3.83
PSC Motorsports 8MB-6MJ - PSC-H6400-6-8 SKU #: PSC-H6400-6-8 $1.40 1 $1.40
PSC Motorsports 18MM x #6 JIC Adapter - PSC-SF01 SKU #: PSC-SF01 $6.90 1 $6.90
PSC Motorsports 16MM x #6 JIC Adapter - PSC-SF02 SKU #: PSC-SF02 $6.90 1 $6.90
PSC Motorsports #6 high pressure hose - PSC-HA2-6HOSE SKU #: PSC-HA2-6HOSE $4.00 1 $4.00
Tax Shippping Total $5.97 $12.43 $113.93
Postby KF5ZXT » Wed Sep 11, 2013 12:08 pm
Sweet, just ordered the above through a guy on Pirate that I had ordered the Full Hydro kit from (jpcrawleram). Saved me $43.93. :D
Users browsing this forum: No registered users and 25 guests
