[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 400: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
Demon4x4.com • View topic - 92 5.0 swap thread
92 5.0 swap thread
Re: 92 5.0 swap thread
Postby Kris Guilbeaux » Mon Aug 12, 2013 8:28 am
We made cuts in the oil pan to make a small sump to hug the drop brackets and we are welding up two holes in the James duff bracket and drilling two new holes in the bracket to get the motor to drop down in the engine bay
Postby TxPlates » Mon Aug 12, 2013 12:51 pm
Have any pictures?
Postby Kris Guilbeaux » Mon Aug 12, 2013 2:13 pm
Postby TxPlates » Mon Aug 12, 2013 3:00 pm
So is the welded piece going to be recessed in the pan? Is that going to limit your capacity and effect it in any manner?
Postby Kris Guilbeaux » Mon Aug 12, 2013 3:14 pm
If it effect capacity it would be less then a 1/4 of a quart so it's a marginal loss
Postby KF5ZXT » Mon Aug 12, 2013 4:56 pm
Nice work.
Postby nice59fordf100 » Sun Aug 25, 2013 9:28 am
We should have the redone mounts soon. Once we have them the motor should sit down further.
Postby TxPlates » Sun Aug 25, 2013 2:23 pm
And when can we expect this machine to be back to being road worthy?
Postby Kris Guilbeaux » Tue Sep 24, 2013 9:04 pm
So after months of head scratching looking at the motor in the engine bay and wondering why is this thing so flippin high in the engine bay. These aftermarket motor mounts put the motor up way higher then I wanted the motor. So, with the help of a welder buddy away I went cutting a notch in the oil pan and modifying the James Duff motor mounts to get this motor to play limbo in the engine bay. So how low can you go 5.0?
New oil pan clearance at the drop bracket
AC compressor clearance at the frame rail
Hey look the exit of the passenger exhaust has clearance now!!!
Looks like I will have AC too.
Room for the transmission to fit too
Steering has clearance too
The motor is sitting in the engine bay as low as I can get it now.
Thoughts? comments?
Postby KF5ZXT » Tue Sep 24, 2013 9:40 pm
, is it now low enough to not need the body lift?
Postby Kris Guilbeaux » Wed Sep 25, 2013 8:00 am
It's closer but I still think the inch of body lift might have to stay on. I think you can do it with out the body lift but I don't think u can keep the ac at the same time. Russell is hoping we can take the body lift off as well but I don't know if this is gonna happen
Postby TxPlates » Wed Sep 25, 2013 8:07 am
Why do you want remove the lift, so it looks more stock like in the movie? If so, when is the bubble roof going in? Lol
Postby KF5ZXT » Wed Sep 25, 2013 8:20 am
Personally, I just don't like body lifts. PLUS, JPX looked better with the real suspension lift. :P
Postby Kris Guilbeaux » Wed Sep 25, 2013 9:21 am
I want the body lift off so I could put the shackles and spacers back on. But I want everything to function on this explorer too so if it means body lift to make it 100% ill leave it on
Postby KF5ZXT » Wed Sep 25, 2013 9:30 am
Can't argue with that. Not sure why you think the spaces/shackles & body lift are mutually exclusive though. You can run the shackles/spacers either way.
Postby Kris Guilbeaux » Wed Sep 25, 2013 9:34 am
I'd rather not run both
Postby TxPlates » Wed Sep 25, 2013 4:04 pm
I like the Trac with her shackles and body lift, but it is a personal preference. Is the JP going to sit level?
Postby KF5ZXT » Wed Sep 25, 2013 4:08 pm
With it's current zero inch lift fron and rear? Or just worried about the extra weight of the motor?
Postby Kris Guilbeaux » Sat Sep 28, 2013 7:20 pm
Parker the truck is currently sitting level and I would assume that it will stay that way lol.
Postby Kris Guilbeaux » Wed Oct 23, 2013 10:18 am
We re-fitted the trans last night as you can see I'm getting much closer to final fitment of the motor and trans
Postby KF5ZXT » Wed Oct 23, 2013 10:40 am
Sweet. Any updated ETOC (Estimated Time of Completion)?
Postby Kris Guilbeaux » Wed Oct 23, 2013 11:06 am
No, because now that I'm close to final fitment I will do a rebuilt on the trans since I do not know the condition and re-seal the motor. Once that is done I can start final bolt in place not to come back out. Then the fun will start with the plumbing of the truck.
Postby Kris Guilbeaux » Sun Jun 01, 2014 8:11 am
So this project is about to go full steam ahead again.. Mainly Cause Bandit Customs has a paying 5.0 swap coming this summer and I need to have all the R&D done on the BC V-8 swap done. Randall this could help you in the future as well. As we plan to make this to where we can knock these out in a month on first gens (providing the parts are sourced a head of time).
I bought this earlier this week. for JPX...
http://www.jamesoaksenterprises.com/ind ... cts_id=609
Couple of reasons for going this route. Transfer case from a stock explorer bolts up, and atlas II transfer cases set up for the 1350 bolt pattern. Less drive shaft mods needed will off set the cost, and will make a better fit and finish in the end.
My plan on JPX is to use the 4r70w Auto trans. This trans is computer controlled and very reliable, with OD.
To install the Advance adapter you need the AOD to 4r70w shaft kit.
http://www.jamesoaksenterprises.com/ind ... cts_id=613
Ill re-post once I get the kit.
Postby KF5ZXT » Sun Jun 01, 2014 8:17 am
Nice. Looking forward to the next update.
Postby Kris Guilbeaux » Thu Jun 12, 2014 7:09 am
Got my adapter yesterday hoping in the next few weeks I get jpx out of the back yard so I can start the final mounting of the motor and trans.
