Demon4x4.com • View topic - Stripe the 93 Limited
Re: Stripe the 93 Limited
Postby Kris Guilbeaux » Tue Oct 29, 2013 9:40 am
Russell only has one sohc and that's his daily... The other is in the company car.
Postby KF5ZXT » Tue Oct 29, 2013 9:41 am
So option A, then.
Postby Kris Guilbeaux » Tue Oct 29, 2013 10:48 pm
Or D I could just wait till I have money to do the r&d
Postby Kris Guilbeaux » Mon Nov 04, 2013 8:49 pm
Since I didn't have enough lunch money for the sohc the ohv went back in the truck for now.
Postby Kris Guilbeaux » Wed Nov 06, 2013 7:12 pm
So I have Russell working I some wiring for the manual trans swap on stripe while I'm painting the valve covers.
Postby KF5ZXT » Wed Nov 06, 2013 7:15 pm
Looking good. Russell must be a handy guy to have around.
Postby Kris Guilbeaux » Wed Nov 06, 2013 7:26 pm
He is handy to have around...
Postby TxPlates » Wed Nov 06, 2013 10:13 pm
Curious as to the reason you went with purple? Parts look good, what kind of paint are you using?
Postby KF5ZXT » Wed Nov 06, 2013 10:15 pm
What's wrong with purple?
Postby TxPlates » Wed Nov 06, 2013 10:34 pm
Nothing, I was just curious.
Postby Kris Guilbeaux » Wed Nov 06, 2013 11:50 pm
Well this truck has purple carpet and purple piping on the seats so Im just bringing the purple out to the exterior too.
Postby Kris Guilbeaux » Wed Nov 06, 2013 11:52 pm
Oh and I I found "plum purple" high temp engine paint at O'Reillys
Postby KF5ZXT » Thu Nov 07, 2013 9:59 am
What's different with the wiring between the automatic and manual setups? Does the auto computer require input from the A4LD? Does the manual computer require input from the manual trans?
Postby Kris Guilbeaux » Thu Nov 07, 2013 10:55 am
Actually yes Randall on both accounts. But most first gens are wired for both auto and manual you would just change the harness for the transmission and you are golden. But sadly this is a limited and ford didn't pre wire first gen limiteds for manual trans. So to keep the PCM from freaking out and make it work like a stock explorer with manual trans we needed to add a few circuits that the limited was missing and delete a few and add a couple 20 ohm resistors. To trick the PCM to think it still has the auto trans in place.
Postby KF5ZXT » Thu Nov 07, 2013 11:04 am
Didn't we do something similar to trick mine into thinking the auto was still in place?
Postby Kris Guilbeaux » Thu Nov 07, 2013 11:07 am
I'm pretty sure we did but I can't remember.
Postby KF5ZXT » Thu Nov 07, 2013 11:10 am
Yeah, me neither. :lol
Postby Kris Guilbeaux » Fri Nov 08, 2013 11:03 am
So now shooting for a possible starting of stripe on weds depending on my funds. I know we will have the trans bolted in this weekend.
Postby KF5ZXT » Fri Nov 08, 2013 11:44 am
Nice. First it will have run since..?
Postby Kris Guilbeaux » Fri Nov 08, 2013 12:40 pm
Postby Kris Guilbeaux » Sun Nov 10, 2013 8:39 pm
Got off work an hour ago and started work on stripe... Oh and I'm posting this from under the truck.
I installed the new rear main seal.
Installed flywheel
And the center force
Postby KF5ZXT » Sun Nov 10, 2013 8:44 pm
Shiny.
Postby Kris Guilbeaux » Mon Nov 11, 2013 10:17 am
So last night before bed I got the transmission, transfercase and starter in the truck. Tomorrow ill be working on getting the exhaust done, crossmember, driveshafts and the top end of the motor.
Postby KF5ZXT » Mon Nov 11, 2013 10:30 am
Manual t-case, correct? Where do you keep finding those things? :lol
Postby Kris Guilbeaux » Mon Nov 11, 2013 10:40 am
They show up at wrench a part more often then you think. There is a 93 xlt out at wap right now with an automatic trans and manual transfercase. The explorer I got this transfer case out of was a black 91 Eddie Bauer with a manual trans and transfercase. And it was factory installed.
Users browsing this forum: No registered users and 26 guests
