by KF5ZXT » Sat Dec 28, 2013 9:59 am
Oh sorry, didn't mean to imply that you needed to do it, just that I needed to fit them in. Lol
The antenna I listed is a no ground plane antenna, but I'd still like to get it in the middle of about a 2' x 2' flat bit of metal. The prime candidate would obviously be the roof. Since I'm concerned about rig clearance for some reason, I'm also considering the middle of the hood. The trade off there being possible interference from the alternator as well as proximity to heat. I'd run the antenna cable under the hood insulation, but I'd still be concerned about the above issues. So, I'll probably just mount it in the middle of the roof. Time to go check out where Rick mounted his.
