by nice59fordf100 » Tue Feb 25, 2014 12:25 pm
Ok will do. yea, that link i sent was just an example. any will work. ive already got the nuetral safety switch wired as well as the tcc lockup feature. is there any adjustment on that shifter? reason i ask is because the neutral safety switch actually closes in park, neutral, and drive...drive not being a position you want the nuetral safety switch in the closed position. i have an idea on how to fix it if the shifter arm is not adjustable
