Demon4x4.com • View topic - 2006 Nissan Xterra Zombie Response Vehicle
Re: 2006 Nissan Xterra Zombie Response Vehicle
Postby BigTim55 » Tue Mar 25, 2014 12:59 pm
so here is the list of parts i need for my conversion
*LIST (will be completed in edit)*
R180 Front Diff (3.36) (or m205 if you go that route)
4wd front hubs (x2)
front cv axles (x2)
front diff mount bracket (LH) )if you need them)
front diff mount bracket (RH) (if you need them)
front diff mounting bolts (x3)
front diff mounting nuts (x2)
front prop shaft bolts (x8)
front prop shaft nuts (x8)
front prop shaft
4wd transmission output shaft
adapter case (connects trans & xfer case)
transmission seal & gasket kit
transmission to adapter case gasket
assembly bolts (x... cant remember, i'll give an update later)
transfer case
rear prop shaft
rear prop shaft bolts (x6)
rear prop shaft nuts (x6)
"Rear Engine Mount Insulator" (that's what Nissan calls it) it bolts the transmission to the crossmember.. YOU NEED THIS
components to manually shift transfer case (we dont need no stinkin electronics)
Postby KF5ZXT » Tue Mar 25, 2014 1:36 pm
So which diff did you get, the R180 or the M205? Anything else on the list that you've already obtained?
Postby BigTim55 » Tue Mar 25, 2014 1:45 pm
Postby 8am8am » Wed Mar 26, 2014 1:52 am
8am8am
Postby BigTim55 » Mon Mar 31, 2014 9:21 pm
Postby BigTim55 » Mon Mar 31, 2014 9:22 pm
So I've been thinking... I need more lights!
Sent from my SGH-M919 using Tapatalk
Postby KF5ZXT » Mon Mar 31, 2014 9:46 pm
well, yeah.
Postby BigTim55 » Mon Mar 31, 2014 9:49 pm
I have a $25 gift card to this place so I'm gonna get these: https://xpeditionoutfitters.3dcartstore ... p_158.html for my reverse lights. And I'm currently in search of a 40" to replace the one I have on my roof.
Postby KF5ZXT » Mon Mar 31, 2014 9:56 pm
I'd recommend the one at
Postby BigTim55 » Mon Mar 31, 2014 10:04 pm
Wow that's actually a pretty good price
Postby KF5ZXT » Mon Mar 31, 2014 10:06 pm
I aim to please.
Postby BigTim55 » Mon Jul 21, 2014 12:05 am
New tires coming tomorrow or Tuesday
Sent from my SM-G900T using Tapatalk
Postby TxPlates » Mon Jul 21, 2014 6:12 am
What did you go with?
Postby KF5ZXT » Mon Jul 21, 2014 6:55 am
Postby MrQ » Mon Jul 21, 2014 8:13 am
Size? New wheels? Decided to go with the new economic al SQUARE series? :p
Postby KF5ZXT » Mon Jul 21, 2014 8:15 am
These ones?
Postby 8am8am » Mon Jul 21, 2014 10:01 am
I have a set of those /\ flex is surprisingly shitty. :(
8am8am
Postby KF5ZXT » Mon Jul 21, 2014 10:02 am
True, but that's the trade off for the decreased likelihood of getting a flat.
Postby BigTim55 » Mon Jul 21, 2014 10:28 am
I'm headed up to discount today. More than likely gonna be staying with my KOs in 315/75/16.
Postby KF5ZXT » Mon Jul 21, 2014 10:32 am
What size are your current ones?
Postby TxPlates » Mon Jul 21, 2014 10:39 am
Aren't your current ones pretty new? If so why bother upgrading at this time if you don't plan on doing any wheeling.
Postby BigTim55 » Mon Jul 21, 2014 10:49 am
I believe my current ones are 265s. My current ones aren't that new but have enough tread left to get bought back for a decent price
Postby TxPlates » Mon Jul 21, 2014 10:55 am
Oh nice, I didn't know they did that. Wonder if they'll take my MTR's!
Postby BigTim55 » Mon Jul 21, 2014 10:58 am
It may just be for tires bought from them, but I'm not sure
Postby TxPlates » Sat Aug 02, 2014 10:28 pm
Any pics of the new tires on?
